eta:=10^(-2.623+(3388.8/(T-491))):
DG:=51749.47800-33.65211624*T-0.4480891609E-2*T^2:
N:=((T/eta)*(exp(108.3606-(3.02397E13/(T*(DG^2)))))):
B:=(1.5438E-6*A*(1307-A))/(10^(-2.623+3388.8/(A-491)))*(1-exp(-abs(51749.478-33.6521*A-0.0044809*A^2)/(8.31*A))):
G:=int(B,A=500..T):
H:=G^3:
J:=N*H:
q:=evalf(int(J,T=500..1307)):
Rcc:=evalf((((4*Pi/3)*q)/1E-6)^(1/4));
hi all;
my orginal function is :
f(x)=(29/2)*x^2-(899/24)*x^4+(26941/720)*x^6+...
i want plot pade approximation and orginal function in the maple 14, i wrote command as follows:
is my command  Correct?
> with(numapprox);
> f := (29/2)*x^2-(899/24)*x^4+(26941/720)*x^6;
> e := pade(f, x, [5, 4]);
> with(plots);
> P := plot(f, x = 0 .. 1, style = point, color = "SteelBlue");
Why does Maple put space after a new string?
How to prevent Maple from doing that?
Screenshot
A plot command with the only argument of
sqrt(75-3*x^2)
used to work (up through version 15).  With 16.02 Maple produces nothing but axes.  It is still smart enough to use its default range for the x-axix and to figure out an appropriate range for the y-axis, but it cannot (will not) draw the curve.
If I were a student wanting to...
hi,
I am trying to make a custom on maple but when i get an error on dynamicSystems saying:
> sys := DynamicSystems[AlgEquation](eq, inputvariable = [Altura(t)], outputvariable = [Teste(t)]);
Error, (in DynamicSystems:-AlgEquation) algebraic equations cannot depend on past/future values of the input/output
But if i change AlgEquation to diffEquation i get no error. I dont have any diff equation on the system. This is happening with one of the "equations":
Hello Everybody!
I am working on an interesting problem right now. Please read it and let me know what you think.
Lets assume there is some function f(v) where v is argument-vector with fixed length. It is known, that the function is a rational type of function with integer coefficients from the vector v.
It is required to find analytic expression for this function.
In other words, we can compute...
hi guys,
I'm working on a project for school that involves te mechanics of billiards; I've derived some equations using mechanics but a part of my project requires me to simulate a simple situation of eg; a collision between 2 equally sized billiard balls, assuming that they are treated as particles and that there is no friction,but there is a coeffecient of restitution to be determined.
If anyone could even push me in the right...
hi, i have a function in Infinite seri's with one unknown parameter and i want to solve it.
I use pade approximation in the MAPLE 15.
is it true!?
this is my function :
written in maple:
> with(numapprox); pade(f, x, [5, 4]);
please help me
thank you
Bonjour,
Comment expand l'expréssion ci-dessous comme un polynome en les variables x,y :
R:=((-lambda*alpha*beta*eta-mu*alpha*beta*eta-nu*alpha*beta*eta-alpha*beta*eta-xi*alpha*beta*eta-tau*alpha*beta*eta)*x+(xi+xi*beta+tau+lambda+lambda*eta+lambda*beta+xi*eta+tau*beta+mu*beta+mu*eta+mu*alpha+xi*alpha+tau*eta+beta+lambda*alpha+mu+eta+nu*beta+tau*alpha+nu*eta+nu*alpha+alpha+1+nu)*x^4+(tau*beta*eta+lambda*alpha*beta*eta+beta*eta+nu*alpha*eta+lambda*beta*eta+nu*alpha*beta+...
I have the following problem in normal 2-D output: Greek letters appear not to show up.
Here is an example of the issue (screen shot):
Hey guys,
I do have a problem with Excel Import.
What I wanna do is import 2 collumns from a Excel-File.
The first Column are the X-coordinates and in the second column are the y-coordinates.
After the import of the two columns (each with around 1000 rows) I would like to run a formula for each of this x/y pairs. Means for example a formula i1:=2*x+y or something like this.
And I would like to get the results also in a...
hey i´m back again and need help to solve this situation Please:                                          restart;with(ArrayTools):                      ...
Like to use a few brief Maple commands in a presentation, but don't want to have the output shown in advance. Is there a way of saving a worksheet without the output or load it with just the commands?
Dear friends
I solve a rectangular system of equations AX=B   where A from order 3m+1x2m      X from order 2mx1       B from order (3m+1)x1   where  m=400, by LeastSquare or by multiply by A^T
A^T*A*X=A^T*X
let M=A^T*A
then     M*X=A^T*X                 finally               X=M^-1 * A^T*X
Dear friends.
How can i increasing or removing the software limits for maple 16.
First 1684 1685 1686 1687 1688 1689 1690 Last Page 1686 of 2471
