When I use the solve command in Maple15 nothing happens. I just want to solve for V and Cf.
Does maple not like implicit equations? The file is attached
hi,
how to solve Ax=0 ?
A is 8*8 Matrix and det(A)=0
how to find x (x1,x2,...,x8) ?
thx;
aryan.
This is the procedure for the question I posted on http://www.mapleprimes.com/questions/128600-Romberg-Approximation-Procedure-In-Maple?sq=128600
Can anyone see where the problem is?
RombInt:=proc(f,a,b,m,n)
local j,k,R;
if type(m, numeric) then
if not type(m,nonnegint) then ERROR("m must be a non-negative integer"); fi;fi;
Hi, I want my output to be column vectors, how do I use the printf statement?
Hello there,
When I was trying to solve a differential equation with dsolve, I've got such a error report:
> dsolve({Q(0) = F[Az], diff(Q(x), x) = q[2](x)});
Error, (in dsolve) found the following equations not depending on the unknowns
of the input system: {Q(0) = -(1/4)*l^2*q[0]-(1/4)*l^2*q[0]*exp(2)+F}
But if I only write:
> dsolve(diff(Q(x),x)=q[2](x));
then there is no problem.
How to find the discontinuities of the function
g:=unapply(int((1-z*(cos(t)+cos(2*t)))/(1-2*z*(cos(t)+cos(2*t))+2*z^2*(1+cos(3*t))),t=0..Pi),z);
over the reals with Maple?
I'm using Maple 7 and got a question:
I've got the function y
y:=x->(x)^0.5; ug:=0; og:=10;
xs:=2;
ys:=3;
How do I create a point with the coordinates [xs,ys] and plot it with the function y in one graphic?
I'm using plot(y(x),x=ug..og); to plot the function y.
Thanks for your help!
flash20001
hi,i want my output be a complex number,how do i use the printf command?for example  s=3+4*i be a output.
Hey, I need to write a procedure to calculate the romberg approximation by combining the trapezium rule approximations. The command will be RombInt(f(x),a,b,m,n), where a and b are the 2 limits and m is a number more or equal to 0 which indicates the number of iterations and n is a integer more or equal to m. Also given is that when m=0, this approximation can be called TrapRule(f(x),2^n,a,b). (I have got the procedure for this traprule, if that helps)
So basically...
Hey, I have made this procedure for the trapezium rule but I get an error when I perform this calculation.
Procedure is
TrapRule:=proc(f,N,a,b)
local k,sum1,h,i:
h:=(b-a)/N:
sum1:=0:
for i from 1 by 1 to n-1 do
sum1:=sum1+f(a+i*h):
k:=(h/2)*(f(a)+2*sum+f(b)):
return (k):
When I try calculating (TrapRule(exp(x),4,-3,1)); I get
Error, (in TrapRule...
Simple question:
Solve y''(x)-y'(x)+2y(x)=10e^(-x)sin(x)
Mathematica answer:
which is correct.
Maple 15 can get the homogeneous solution (the first two terms) but the particular solution? Not as we know it.
y(x) = exp((1/2)*x)*sin((1/2)*sqrt(7)*x)*_C2+exp((1/2...
I am evaluating a difficult integral of an oscillating function.
f:=k->evalhf(piecewise(k=0,1,k>0,cos(k*(dz))*BK0(k*rho1)/BK0(k*a)));
evalf(Int(f, kmin..kmax, method = _d01akc,epsilon=eps,maxintervals=1000000))
with dz>0 and possibly very large
kmin is Pi/(2*dz)
the number of cycles is nc = ceil((1/2)*kl*dz/Pi) with kl = 91.563
kmax=  kmin+nc*2*Pi/dz
Each evaluation of this integral using a call to the NAG routine (_d01akc ) eats up
this is a link:
I'm using the printf command and i want my output a decimal number to get it published
s1=0.5555552487 and f(s1)=0.2542365647 what should i do?
hi;
when run file , maple give wrong result, plz help me
my file is attached
thx
 EKM3-cylindrical_pan.mw
First 1833 1834 1835 1836 1837 1838 1839 Last Page 1835 of 2471
