Hi:
I have justdiscovered that the following "simplify" command gives the wrong answer on Maple 11. Could someone please check to determine if Maple 14 does any better?
> S1:=Sum(1/GAMMA(j+1)/GAMMA(2-j)*GAMMA(1+a-c+j)*GAMMA(1+a-b+j)/GAMMA(a-
> 1+j)*GAMMA(-2+b+c-j+n-a),j = 0 .. 1);
> Ans1:=simplify(S1);
My array contains numbers like
[ 0.333333 0.211111]
I used the command
interface(displayprecision=3)
and it is displayed  [ 0.333  0.211]   (which is ok).
However, when I send the output to latex
latext(%)
I get again [ 0.333333  0.211111].
How  could I display  only 0.333   after using LATEX(%)?
I have to prove a trig identity with Maple for class. It's rather simple, but I can't figure out how to get the right-hand side into the form I want. What I have is:
tan(x)^2*sin(x)^2 = sin(x)^4/cos(x)^2
I simply want to convert sin(x)^4/cos(x)^2 into tan(x)^2*sin(x)^2.
The conversion is apparent to anyone looking at it but I simply cannot figure out how to put it in the right form, and I can't change the left-hand...
I have those functions
M:=n->piecewise(And(n::integer,(n/p)::odd),((4*Br)/(mu0*Pi*(n/p)))*sin((Pi/2)*(n/p)),0);
W:=(n,r)->piecewise(And(n::integer,(n/p)::odd),(M(n)*r)/(mu1*(1-n^2)),0);
u1:=(r,theta)->sum((r^n*AI[n]+r^(-n)*BI[n]+W(n,r)*sin(n*theta0))*sin(n*theta)+(r^n*CI[n]+r^(-n)*DI[n]+W(n,r)*cos(n*theta0))*cos(n*theta),n = 1 .. nn);
diff(u1(r,theta),r);
Error, (in type/polynom) too many levels of recursion
I need to find a specific temperature which I named T2 to cross the zeroline in a plot but maple doesn't plot or give a solution at all. I'm very confused and also new with this software.
My code is as follows:
R = 8.314472;
> A = 1.935;
> B = 36.915*E-3;
> C = -11.402*E-6;
> P2 = 10*10^5;
> P1 = 101300;
> T1=365;
> Tc=425.1;
> Tw=T2/T1;
> Pc = 37.96*10^5;
> Pr1=P1/Pc;
I have got a question. I have an Hamiltonianfunctionand want to differentiate this function to all variables. There is no problem with most of the variables, but one doesn't work. The error above occures, when I use the button "execute the entire worksheet". When I just press Enter, the errror does not occure and the right results are presented. But I am not abel to use the results.
Has anyone an idea how I can solve this problem?
I do not have any experience with maple and have a homework assignment due tomorrow. I have been staring at a screen blankly for an hour now trying to research how to do this but have had no luck. Here is my problem...
compute the projection of w onto v. call proj w onto v "p" and let q be vector perpendicular to p so that p+q=w. plot all four vectors together.
I have no idea where to even begin. I can do this by hand but it's the computer stuff...
Hello.
After using my command FOR --DO (see the commands below of the attached file) I would like that appears only the last graphic ( and not the previous "plot"s neither the matrix ww).
How could be done it?
Thanks in advance,
Jean-Jacques.
#POUR FAIRE LE "FOR FROM BY TO DO"
max1:=60:
q:=1/2:
for w1 from 1/27 by 7/27 to 1/2 do
ww:= [seq( [n, add(1/(n+1), k=ceil(  max(0,(q-w1...
Hello, I am using maple 7 and I want to find all the solutions to a set of 4 equations with 4 variables.  These equations are all trigonometric.  fsolve of course only gives a single solution and using the avoid unction doesn't work.
I have tried to write something like this:
Sol1:=({equations},{vars})
Sol2:=({equations},{vars},avoid=Sol1)
and this always gives the same solution.  Any ideas?  Thank you.
Hey folks I have a question regarding how to fill an Array.
Lets say I do this...
Array(1..10, [seq(i, i=0..9)]);
This produces [0 1 2 3 4 5 6 7 8 9] as output which is fine.
Now lets say I want a 2x10 array (2 rows, 10 columns), the top row being the digits 0-9 (as above) and the second row being something else (in this case it is counting the number of times each digit appears in Pi)
I would like to use Maple to visualize some data produced by a computational geometry application I am working on.  However, my coordinate system is different than a standard cartesian system.  In my case, the positive Y direction is downward.
Can I re-orient the Y axis on a point plot to go downwards instead of upwards?
Greetings,
I want to solve the non linear recurrency system:
x[1](k*T+T) = x[1](k*T)+2*u[1]*psi*cos(alpha); x[2](k*T+T) = x[2](k*T)+2*u[1]*psi*sin(alpha); theta[0](k*T+T) = theta[0](k*T)+T*u[2];
with:
psi := piecewise(u2 <> 0, sin((1/2)*T*u[2])/u[2], (1/2)*T); alpha := theta[0]+(1/2)*T*u[2];
and u1 and u2 some functions of x1(kT) and x2(kT).
I tried to use the rsolve command but didn't work.
Can you help me, please? Is there some way to solve this?...
ex1 := {
evalDG( d(x) = w1*e1 + w2*e2),
evalDG(d(e1) = w12*e2 + w13*e3),
evalDG(d(e2) = -w12*e1 + w23*e3),
evalDG(d(e3) = -w13*e1 - w23*e3)
ExteriorDerivative(ex1);
> ex1 := {evalDG(d(e1) = w12*e2+w13*e3), evalDG(d(e2) = -w12*e1+w23*e3), evalDG(d(e3) = -w13*e1-w23*e3), evalDG(d(x) = w1*e1+w2*e2)}; ExteriorDerivative(ex1);
{d(e1) = w12 e2 + w13 e3, d(e2) = -w12 e1 + w23 e3, d(e3) = -w13 e1 - w23 e3,
  d(x) = w1 e1 + w2 e2}
Is there a way to export a file from Maple so that somebody without Maple can use ? My project is a dynamic one with components that need to be used by the "Reader".
Yaad
I have a rather large output of quotients of polynomial terms in Maple, things like coeffiencient*r^6*(sqrt(1+r^2...)/(1+r^2+r^4), what I have to do at the moment is scan through them by eye taking the large r limits, to see if e.g. an expression goes like 1/r, or 1/r^2 etc at large r..
I was wondering if there is anyway I can automate Maple to scan through the terms for me, systematically taking each limit, and only keeping terms to a certain power in r?
First 1938 1939 1940 1941 1942 1943 1944 Last Page 1940 of 2463
