I am plotting flux values using contourplot3d. But I am only allowed to give two colors in contourplot3d option (eg. coloring=[red, blue]). This gives a contour plot that is a combination of these two colors. eg. But i want different colors to denote different flux ranges and so I need atleast 4 colors. Is there anything I can do? Thanks
Hello, I have about 80 equations for x and 80 equations for y. They are called Sx_0 .. Sx_80 for x and Sy_0 .. Sy_80. They all depend on parameter m.
I want to define a new piecewise function P such as,
P evaluated at m=i  is equal to [  Sx_floor(i) evaluated at i , Sy_floor(i) evaluated at i ]
For example,
I want to derive an incompressible Navier Stokes equations with Maple for Conical Coordinate System.
In the beginning I'd like to derive NS equations in the Cartesian coord. system:
with(Student[VectorCalculus]):
V:=VectorField();
NS:=Diff(V,t)+DirectionalDiff((V . Del),V)=-Gradient(P)/ro+ni*Del . Del . V
Obviously something wrong with this writing.
Please help
Mark
I want to know how to represent a summation of the form:
and solve for xn.
My reason is that I want to solve:for yn where MUx is the average for x ditto for MUy.
i have a question with plotting i have a vector X of length (10) and matrix U, that its size is (10,20), how can i plot the vector X with each column in matrix U in the same figure ????????????????
I wonder how the following piecewise function can be plot in maple (showing the dirac function).
f := piecewise(t < 0, 0, and (t >= 0, t < 1), 1, and (t >= 1, t < 2), (-2+t)^2, t > 2, t = 4, Dirac(t-4))
plot(f,t=-10..10) does not show the dirac function.
Many thanks
Ed
PS.  I saw a solution using op but I could not follow what was done.
I have defined an expression f. This expression f, when integrated from 18 to b, is equal to 20. My goal is to find this b value. Since the integral is very hard to solve symbolically. This is what I did:
with(Student[Calculus1]);
ApproximateInt(f, t = 18 .. b, method = simpson);
by trying some random numbers v, I have found the approximate value of b.
I am trying to point plot R:= .8*theta+.87 where theta starts from 160 degrees and goes till 330 degrees. I want to see points only at 160 degrees, 170 degrees, 180 degrees and so on till 330 degrees . It should be a polar plot. If I use plot( .8*theta+.87, theta=(160/180)*Pi..(330/180)*Pi,coords=polar), I get a continuous line. I just need points. thanks
Hi everyone!
I have an urgent problem!  I am dealing with an autonomous system of 2 differential equations.
First of all I have to plot  the phase plane (x,y) but I'd like to include a constraint (x^2+y^2<1 )in my system and I don't know how to do that!
what I've done by now:
>dfieldplot([diff(x(N),N)=-3*x(N)+sqrt(6)*(y(N))^2+3/2*x(N)*((x(N))^2+1-(y(N))^2), diff(y(N),N)=-sqrt(6)*x(N)*y(N)+3/2*y(N)*((x(N))^2+1-(y(N))^2)],
 [x(N),y(N)],N=0..20, x=-1..1, y=0..1, color=black, dirfield=[30,30]);
<p>Hi </p>
<p>I have some funtio<img alt="" src="file:///C:/Users/BrianBak/AppData/Local/Temp/moz-screenshot-5.png" />ns that a generate using maple. I would like to be able to set an variable equal to the right side of these functions in matlab. I have saved the funktion in the following way. </p>
<p><img alt="" src="file:///C:/Users/BrianBak/AppData/Local/Temp/moz-screenshot-6.png" /><img alt="" src="file:///C:/Users/BrianBak/AppData/Local/Temp/moz-screenshot-7.png" /><maple>with(CodeGeneration)</maple><br />
<maple>Matlab(x^2+y^3, output = "file.txt")</maple></p>
How do I prove this on maple through a graph?
Here is my problem:
How many horizontal asymptotes can a rational function have? upport your answer with an explanation in your own words along with graphical support using Maple.
Plot on the same coordinate system:f(x)=square root of x  and g(x)= - square root x + 4-18 then use Maple text to describe in f(x)words the change in to create g(x).
Hello, recently I am trying to generate fortran codes for the proc below:
Give an example of a rational function with vertical asymptotes at x=6 and x=(-2) with a zero at x=3. Show both the function rule and a graph using Maple illustrating the required asymptotes and zero.
Please show me what function to use to graph this.  I'm very lost.
First 2043 2044 2045 2046 2047 2048 2049 Last Page 2045 of 2459
