i got some problems trying to run the example test.java. I have Maple 13 on a ubuntu machine.
for your info:
$MAPLE=/home/thomas/maple13
$LD_LIBRARY_PATH=/home/thomas/maple13/bin.IBM_INTEL_LINUX
Now the problem:
Compiling the java file works, but when I try
java -classpath "$MAPLE/java/externalcall.jar:$MAPLE/java/jopenmaple.jar:." test
this exception appears:
Error loading libraries: java.lang.UnsatisfiedLinkError: no jopenmaple in java.library.path
I don't know how to tell maple to approximate automatically all the results, for just not having to do right click->approximate
Thanks in advance!
I've been using Copernic Desktop Search for a long time now.  It's the perfect tool for me when I want to find files that contain specific words.  But now that I have more than 1 gig of files with extension *.mw (and all the others that come with other version of Maple), I am in the need to find a way to search in thoses files.
I have this Maple code that calculates the Sharpe ration= Expected return portfolio / Standard deviation return portfolio
for a pair of stocks by using permuations [ stock[i], stock[i] ]. Each stock shows up the permuation list twice first in
[ here, not here ]  and  [ not here, here ] so I just itterate over such permuation list and take a long position in the
first stock ( +1*return) and a short position in the second stock (-1*return). So I get the Sharpe ration for all
Hi all I'm using a set of parameters, such as {a=1.b=2,c=3} to do various manipulations of an ODE system. Then later I want those parameters to be assigned their respective values, but I'd rather not have to do a:=1;b:=2;c:=3 Is there a way to do that ? Thanks LR
Dear All:
  I have type such expression in maple 2D Input
L[out_inductor] := 8e-6;
The result shown as L[out_inductor] := 0.80e-5; but if i change the numeric formatting to scentific, the result style change as below: 8.00*10^(-6) , the variable name L[out_inductor] missed in 2D output , it still disppeared even i change numeric formatting to none.
so i want to need some help me, how can i let variable name L[out_inductor] show in 2D output when the numerric formatting is scentific.
This problem has ocurred a few times and is quite troublesome.
Does there exist a way in Maple that you can detect a change in a text file without having
to constantly having to call the readdata which keep the command prompt busy in Maple.
For example if you have a txt file that is constantly updating it self with new data
I want the matrix in Maple to be updated dynamically by adding the new data.
Is this possible ?
I am trying to code a naive method for checking if a number is prime. where it checks if a number is prime by checking if a number 'k' divdes into n.
Hello, i have attached the file here.
Basically i have an eighth order equation in m. This will produce eight solutions of m. Then i need to substitute each solution of m into a matrix, say M. Thus generating a matrix for each m value. Can someone show me how to do this please...
Greetings Is there a nice way to obtain the jacobian of a system of ODEs ? For example with restart: ross_x:=diff(x(t),t)=-y(t)-z(t): ross_y:=diff(y(t),t)=x(t)+a*y(t): ross_z:=diff(z(t),t)=b+x(t)*z(t)-c*z(t): rossler_sys:=ross_x,ross_y,ross_z; I can't seem to find an easy way to do it, other than re-write the system altogether s_x:=-y-z: s_y:=x + a*y: s_z:=b+z*(x-c): J:=Matrix([[diff(s_x,x),diff(s_x,y),diff(s_x,z)],[diff(s_y,x),diff(s_y,y),diff(s_y,z)],[diff(s_z,x),diff(s_z,y),diff(s_z,z)]]); .....which seems horrible. Thanks LR
Hello! Why does Maple not compute the following residue? residue(((x^7+1)^4/x^30), x=0); Maybe the powers are too high? Are there any parameters I can set so that Maple produces a result? Thanks! Marco
How can I tell Maple to read all txt files in a specified folder ?
The names of each txt files are different ( I dont know the names )
Using maple help: wiht(plots): animate(plot, [Ax^2, x = -4 .. 4], A = -3 .. 3, trace = 5, frames = 50) the above command shows a plot with no animation... What's wrong?
*sigh* Mathematica,
how do I plot the bifurcation diagram with Maple of the function:
dx/dt = rx - sin(x) ?
First 2074 2075 2076 2077 2078 2079 2080 Last Page 2076 of 2459
