I would like to get to the numeric values that are calculated by creating a plot using implicitplot.
Any help or pointers are greatly appreciated.
M.
Windows Vista Home Premium+Maple 13+Maple toolbox for MATLAB 13+Matlab R2009a
Error Message: MATLAB not found!
I am confused with this question. I have parabola1 which is 3*x^2-22x+7, and parabola2 which is -5/9*x^2+58/9*x-161/9. the area of par1 is −148.1481481, the area of par2 is −1.280000000.
How can I Calculate the area A3 which is defined by the intersections
of Par1 and Par2.
and Plot Par1 and Par2 with the area A3 “highlighted
Hi guys, I am struggling with these three equations. The first is a nonlinear equation which can be solved numerically with the boundary conditions y(infinity)=0 and y'(0)=0. a1 := diff(y(r), r, r) = -2*(diff(y(r), r))/r-1.3*10^12*polylog(3/2, exp(b(u-y(r)))) Now y(r) depends parametrically on u and b which can be determined using these equations: a2 := -1.5*10^8*(int((3*polylog(5/2, exp(b(u-y(r))))/b^(5/2)+y(r)*polylog(3/2, exp(b(u-y(r))))/b^(3/2))*r^2, r = 0 .. 10)) = -129000 a3 := 3*10^8*(int(r^2*polylog(3/2, exp(b(u-y(r)))), r = 0 .. 10))/b^(3/2) = 1
I am having a problem in indexing a given matrix to be used in sigma. How can I make this work? x-y coordinate method > xy := Matrix(5, 2, {(1, 1) = 10, (1, 2) = 10, (2, 1) = -14, (2, 2) = -2, (3, 1) = -10, (3, 2) = -10, (4, 1) = 4, (4, 2) = -24, (5, 1) = 10, (5, 2) = 10}); > n := LinearAlgebra[RowDimension](xy); = print(`output redirected...`); # input placeholder 5 > > x := LinearAlgebra[Column](xy, 1); = print(`output redirected...`); # input placeholder Vector[column](%id = 194172504)
I am attempting to solve the following problem with maple:
3 ∙ x ≡ 1 (mod(2))
Yet when entering this into maple I get the following error:
Error, invalid input: modp expects 2 arguments, but received 1
So how would one enter this problem into maple?  What other argument would need to be entered or can maple even solve this?
stats[random,binomiald[400,1/2]](4);
                            88, 88, 88, 88
The first four values generated by the binomial random number generator
with n=400 and p=1/2 are all equal to 88? I must be doing something wrong.
Any ideas? (I am using Maple 8)
Byron Schmuland
I know this sort of simplify question has been asked many times, but I still don't seem to have 'got it'.  In a nutshell, there's a conservative real 2-D vector field (cartesian X,Y coordinates) with an extra non-positive parameter Z, and Maple 12 is able to compute the scalar potential.  But it presents it in a long (6 lines), perversely complicated form, involving the imaginary sqrt(-Y^2).  I tried to show it here using the Maple leaf Tag and pasting the expressions there, but all I got was indecipherable ascii.  The vector field X and Y components are
    I want to find a relation between tow sets of discrete points. So I must plot a curve with these dicrete point pairs. But  the two sets points don't have a explict relation (in fact, the relation just is that I want to find) How  to treat the discrete point pairs with maple? Thank you very much!
Best regards!
I was wondering if there was a way to have two background plots on an animation?  I would like 2 seperate parts of the animation to remain constant but I can't figure out how to do that without connecting the seperate parts.
hi, I m pretty new with maple,  could someone tell me how to calculat the area of parabola and x-axis,the equation of parabola is 3x^2-22x+7,
Hey so I've been given a set of data, I was told to make a scatter plot which i did now I have to:
Use the regression feature of Maple to find a linear model of the data.
I don't know how to do this. What I have right now is:
> data := [[2005, 2.85], [2006, 5.70], [2007, 10.0], [2008, 14.8], [2011, 25.0]];
> with(plots);
> pointplot(data);
What's the next step?
I'm looking to display some results in my for loop but not others.  This is my code:
for j from 0 to 10 do
    fileName := sprintf(`destination%d.txt`, j):
    datalist := readdata(fileName, integer, 3):
    pointplot3d(datalist, style = line, linestyle = solid, thickness = 5);
I'm sort of new with Maple and programming so I would like to ask a couple of questions related to Matrix polishing / changing numbers in Matrix. The example code is as follows:
First 2154 2155 2156 2157 2158 2159 2160 Last Page 2156 of 2459
