Hi! Does anybody know which algorithm is used when the command "InterReduce" is envoked? I'm using Maple 12 and I want to interreduce a list of four homogeneous polynomials in 9 unknowns. I thought that "InterReduce" would use the F4 algorithm to reduce the polynomials, but the process does not finish, even after six hours. When I interreduce the polynomials "by hand" using the command "Reduce" everything is finished after 10 minutes. So, the question is, what does "InterReduce"? Which algorithm is used? Thanks a lot!! domo
I'm using Maple 11 and trying to export Maple plots to Word 2007. However, no matter what I do, the quality is always quite poor. In detail the plots look like in a low resolution, i.e. lines are not smooth, although I have already set the resolution to a higher value. What would be the best way to do this? Any tips?
Thanks in advance,
Ciccarese
I got an expression: R:=(2*E-2*sqrt(E)*sqrt(E-V0)-V0)/(sqrt(E)+sqrt(E-V0))^2; I would like to plot R as a function of E/V0. I tried to substitute E=mu*V0 to R, then plot(R,mu=0.1..1),but failed to get the plot. How can I get the right figure? thanks.
<p>I have a 16x1 matrix in maple, and maple only displays: [matrix 16x1; data type: anything; storage:rectangular; order: fortran_order]</p>
<p>I want to actually see all the numbers, and not by applying the command v[i] for i = 1..16.</p>
<p>Is this possible??</p>
<p>I tried eval(v) but it still gives me the same result.</p>
how can I save a generated plot *and* show it on the screen (just like default-setting) at the same time? Using the plotoutput-command, it accepts only one out of the two options. Preferably, the size of each output (file and screen) can be set independently.
System: Maple 12 Worksheet mode.
Thank you guys very much in advance!
Ben
I want to use a term after it has been isolated.
For example, say that I have equation1 (eq1) and I want to use the y term in the next equation, s.
eq1:=x+y=2;
isolate(eq1,y);
s=z+y;
This returns s=z+y not s=z+x-2. I would like s=z+x-2. How do I do that?
I am trying to do animated plots of vector fields and I'm running into a problem with the fieldstrength parameter.
Basically the way a typical vector field plot works is that every time it plots a vector it scales it by some amount based on field strengths of the other vectors on the plot.  So for example, if you use the "fixed" option it scales arrows by 0.9 times the maximum arrow size for the grid.
I have a nonlinear algebraic system with x ,y unknowns and beta parameter (0<beta<1); I want to plot in 3d the triplets (x,y,beta), where x and y are the solution of system for ten different values of beta.
For now I am able only to solve the system with fsolve, but I don't want to copy the solutions with copy and paste, because in the future I have to give to beta much more values than 10. Can anyone help me, please? This is the program:
F:= <<-3u|u|u|u>, <u|-3u|u|u>, <u|u|-3u|u>,<u|u|u|-3u>>;
There is a very nice sheet by Sergej Moiseev Orthogonal Functions, Orthogonal Polynomials, and Orthogonal Wavelets series expansions of function at the Application Center, www.maplesoft.com/applications/app_center_view.aspx.
I am trying to create a simple loglogplot, but i am getting an empty plot error. Here is my code:
c:=2.998*10^8;
<p>I live in Los Angeles near UCLA and was wondering if there are Maple users in the neighborhood of Los Angeles who would be interested in forming some sort of local Maple Users group.  I would appreciate hearing from possible members,</p>
I'd like to know how to insert the following differential equation in maple 12 (or older doesn't matter that much) without incuring a - Error, recursive assignment -
Plaese note that, in the orignial text, a dott is added over the variable x1:
 x1(dot) := -2*a*x1*(x1-1)+(1-b)*x0
and that this differential equation describes change in the number of entities (x) that move through state 1, there a couple of more equations but i can't figure out how to insert the above one in maple correctly.
please help me here. I want to simplify the expression:
(-f(xn)^2*f(zn)+f(xn)^2*(D(f))(zn)*zn+f(xn)*f(zn)^2-2*f(xn)*f(zn)*(D(f))(zn)*zn+(D(f))(zn)*xn*f(zn)^2)/((D(f))(zn)*(f(zn)^2+f(xn)^2-2*f(xn)*f(zn)))
I just compied it directly from maple
Hi, I'm running into difficulty regarding plotting an array I have.  I have an array of 500 elements and each element corresponds to an even integer.  Hence I want to plot for x=1..1000 where array[1] is plotted at x=2, array[2] is plotted at x=4 etc, and the odd numbers are left empty.  How do I do this.  I tried
fn := proc(n)
  global array:
  if n mod 2 = 0 then return array[n/2]:
  end if:
First 2189 2190 2191 2192 2193 2194 2195 Last Page 2191 of 2464
