hi all, sorry, i'm a newbie on maple
i have to simplify some equation, then i heard that it can be done by maple. so i tried using maple 10 to simplify my equation.
but after i write down the equation, and press enter, i got "unable to match delimiters" message. what should i do to get the simplified equation?
here is the equation:
I trying to fit an Eckartfunction with 3 parameters to my curve I've calculated with gaussian03 (IRC).
my given points for the curve are:
with(VectorCalculus):
SetCoordinates( 'cartesian'[x,y] ):
How do I make  animations of an ellipse? E.g. stretching, rotating, translating in both the x an y direction? I thought it was easy task, but after several hours I still have no solution.
Anyone?
kind regards,
Harry Garst
is there any way that cartesian eqns can be converted to parametric  and vice versa in maple?
den1 := (1/2)*((2+x^2)*sqrt(4+x^2)+2*sqrt(4+x^2)*cos(t*sqrt(4+x^2)*tau/`ℏ`)+sqrt(4+x^2)*(cos(t*x*tau/`ℏ`))(2+(2+x^2)*cos(t*sqrt(4+x^2)*tau/`ℏ`))+x*(4+x^2)*sin(t*x*tau/`ℏ`)*sin(t*sqrt(4+x^2)*tau/`ℏ`))/(4+x^2)^(3/2)
den2 := 4*cos((1/2)*t*x*tau/`ℏ`)^2*sin((1/2)*t*sqrt(4+x^2)*tau/`ℏ`)^2/(4+x^2);
den3 := 4*sin((1/2)*t*x*tau/`ℏ`)^2*sin((1/2)*t*sqrt(4+x^2)*tau/`ℏ`)^2/(4+x^2);
I am trying to import data from Vernier's LabQuest for curve fitting in Maple 11. I can get a .CSV file which appears to be loaded in Maple  11 but I cannot get it in a format that I can use the polynomial interpolation command. Is there a step-by-step instruction set somewhere that I can follow that will walk me through the import to final polynomial fit? The data is titration data with over 1000 pairs of data ... way to much to imput by hand.
Thanks for any help.
Consider plot3d(....); if I write plot3d(....,color=red); it will be colored in red. Now I want instead to be colored according to pop-up menu for graphics: say Z[hue]. How can I specify this? Thank you. Victor
I'm optimizing a procedure so that it can work as fast as possibly can.
How do I find out how long it takes for maple to make a calculation?
I did evalf(3^1000000,1000) or something like that on a laptop.  It was taking a long while so I pressed the interupt (stop hand) button.  Nothing happened, it didn't stop.  It did finish what it was doing but it didn't immediately stop.
Unless it was trying to update the screen with all the numbers I think maple should have just stopped whatever it was doing and give me back control.
1) How to instruct Maple to assign hotkey Cmnd-N (on Mac) to New Worksheet rather to New Document? 2) How to create a new document/worksheet in the new window rather than in the new tab? 3) How to open a already open tab in the separate window?
Is there an equivalent Maple command for the "angle" command in Matlab?
I'm trying to get the phase angle out of a complex number.
I want to be able to do the following in Maple 1) Set up the current value hamiltonian H:=u(c(t))+lambda(t)*(f(k)-c(t)-delta*k) ; 2) Take the foc with respect to c(t) which should give me u'(c(t))=lambda(t) 3) Differentiate with respect to time which should give me u''(c(t))*diff(c(t),t)=diff(lambda(t), t) 4) Divide both sides by u'(c(t))=lambda(t) should give me u''(c(t))*diff(c(t),t) / u'(c(t)) =diff(lambda(t), t) / lambda(t) I have tried to set up the hamiltonian in maple but I find it quite hard for numerous reasons: A) I cannot differentiate a function w.r.t a function i.e
Absolutely amazing. Absolutely every single time I go to Maple to invert a matrix,
the syntax changes. Sometimes it can recognize M:=[[1,3],[2,5]] as a matrix. Then the next time it never will. It requires M:=Matrix([[1,3],[2,5]]); Sometimes it is MatrixInverse(A). Other times it is MatrixInverse[A]. Other times a matrix must be written as <<1,3>|<2,5>>. Sometimes the command is with(LinearAlgebra). Other times with(LinearAlgebra[Generic]). Some of these commands on in the Help menu. Other times they cannot be found.
Hi, I'm trying to find the first few roots of the Bessel function (1st kind) for a few different values of v, but I'm new to Maple and am having some trouble.
This is what I've tried:
u:= v->BesselJ(v,x);
solve({u(0)=0},{x});
                            {x=RootOf(BesselJ(0,_Z))}
evalf(%)
First 2259 2260 2261 2262 2263 2264 2265 Last Page 2261 of 2458
