hi, if generate 10 random 0 and 1's by using the following maple code > restart: > coin:=rand(0..1): > coin_1:=proc(n) seq(coin(),i=1..n) end: > data1:=coin_1(10); How can I count the number of sequences that have a lenght equal to 1 zero, 2 zero, 3 zero, 1 one, 2 one, 3 one etc etc and how can I plot it in a histogram to illustrate the law of large numbers alex
When I use maple in the shell of Linux, I  always get this kind of output of polynomials:
  2       2
a  - 2 y  + b y.
My question is could I get them in more regular form,
a ^2 - 2 *y^2  + b* y.
Any idea?
Using maplets, how can i get a button on the form to point to another form with a picture. So i am hoping to have 3 forms A1,A2,A3, each have 3 buttons, one to point to the next form, one the previous and one to shutdown. I can create the buttons on the form, the problem is having one point to another, thanks.
Has anyone implemented https for Maple T.A. 3.01? Mainly we are looking to secure the login and password information, but if everything must use ssl, that's ok. Thanks.
-Jeremy Sieminski
Bonjour
Je voudrais savoir s'il était possible de faire fonctionner un maplet sans la visionseuse mapletviewer. Et dans le cas contraire la faire fonctionner à travers un serveur maplenet, Mais je ne sais pas comment m'y prendre. Quel est la démarche à suivre ?
Merci de votre aide.
I've problem to make the plot to animate [plot]. Please help. Thanks. Below are the commands
Expand the Dirac delta function in a series of Legendre polynomials using the interval
-1 <= x<= 1.
thanks,
v/r,
Download 285_Arfken 12.2.5.pdf
View file details
Can anyone help with number 12.2.5?
thanks,
very respectfully,
Is there any command or Maple package for computing subresultant sequences of two polynomials? It is hard to believe that Maple doesn't include this basic facility but I can't find it anywhere.
Peter
Why lhs cannot be resolved? Well, it can be, in fact, if the interval is t=0..0.03, say, but I need to use t=0..infinity, or t=0..smthbigenough. Thanks.
fsolve(1-erfc((1/2)*sqrt(2)*sqrt(t)) = 0.5e-1, t, t = 0 .. infinity) = fsolve(1-erfc((1/2)*sqrt(2)*sqrt(t)) = 0.5e-1)
It is very stranger that these two statements are not equative:
evalf(Int(x*sin(x)/(1+(cos(x))^4),x=-Pi/2..Pi/2));
 1.845096351
 evalf(int(x*sin(x)/(1+(cos(x))^4),x=-Pi/2..Pi/2));
 1.323830675+0.*I
I think the first one is correct. In fact, the exact result is
 2*hypergeom([1/4, 1/2, 1, 1], [3/4, 5/4, 5/4], -1);
u can evalf the above answer to check it. In fact, Maple cannot get this analytic answer, how do I get it?
Hello:
      i have a presentation in recent days.  in this presentation i need copy some formula result in maple to Powerponit. But when i copy formula directly, it shows discorder code in Powerpoint.
    so does anyone has good method?
   thanks very much!
Solve differential equations using type=series option. How can I judge the series is convergent? Can I obtain the expression of general term?
If I try this
solve({1*x+(1/2)*y+(1/6)*z =1,(1/2)*x+(1/6)*y+(1/24)*z =0,(1/6)*x+(1/24)*y+(1/120)*z =1}, {x,y,z} );
Maple 11 gives me the answer {x=63, y=-384, z=780}
However the book mathematical problem solving with computers (2002) maple 5.3 gives an answer of
{x=39, y=-216, z=420}
My algorithm counting the number of data points between consequitive positive integers in a list seems to be very slow. I suspect there may be a considerable improvement - please help see how to achieve it. If it can be done faster with zeros only, let it be so. See Thanks.
First 2286 2287 2288 2289 2290 2291 2292 Last Page 2288 of 2464
