Hi dear Maple's experts, 1.- If I have a variable r0 := x^3, Then, I can save r0 in a file: save r0, "myFile.txt"; Now, if I have some additional variables r1:= y^2+ 10; Is it possible to add r1 to the previous already created "MyFile.txt" (without overwriting the initial file)? 2.- When I work in Maple 10 (worksheet mode).. I woult like not to have to press "F5" to switch from "C 2D Input" to "C Maple Input" . Is it possible to set up "C Maple Input" as default option to write the comands? 3. When I write usually the commands appear in red.. and output appears in blue..It is possible change this colours?.
As a newbie to maple, I was wondering how do I find the maximum of a equation under contraint. i can find some but for this one I can't ... and it's getting to me f=1000*x+7500*y under constraint: g=10000000-(20000*x^0.8)*y^1.2 and for f=(20000*x^0.8)*y^1.2 under constraint: g=125000-1000*x-7500*y Who do I find the maximum using MAple 10 !!!???? Tx for the help
Hi All, I have the following graph: plot([(x/(2*sqrt(x)-3)),(-x+5)],x=-10..10,y=-4..6,discont=true, color=[red,navy], thickness=2); how do I a) label the two functions so that they are visible in the graph i.e. L=-x+5 beside the blue line and f(x)=x/(2*sqrt(x)-3)) in pretty text beside the upper red function? b) I wish for a dashed blue line (-x+5) instead of constant. Thanks in advance for any help :-) Robert
Does anybody know how to install the 10.02 update on a 64-bit version of Maple? -- Regards, Franky.
We have an automated grading system and sometimes students assign values to variables that are useful in grading their assignments. In order to get around this I've been tinkering with the anames() command (specifically, anames(user)), but I cannot seem to get a usable list of "in use" variable names: Every time I try to get Maple to use the list that anames(user) returns, I get the evaluated variable and not the variable name. Example: >a:=4; >anames(user)[1]; 4 Does anyone know how I can get a usable list of variable names that have been assigned values?
Hello Maple insiders, I'm still learning to get along with Maple (version 10.01). Currently, I would like to have a small procedure which creates a random matrix of arbitrary dimension with complex floats. However, the generated matix, say A, has to fulfill the following conditions (because it should be a valid physical density operator): 1.) A is hermitian 2.) A is positive semidefinite, together with 1.) this should mean that A has only real and nonnegative eigenvalues 3.) A should have trace equal 1 With the randomly generated matrices I would like to cover (reasonably uniformly) the set of all possible matrices with the above constraints.
Hi, I would like to be able to plot a 3d surface of one variable, with another variable in colour on that surface. This plot should have a legend for the colour variable. At a stretch, I would also like to have all of this in polar co-ordinates, with polar axes and without having to write a transform myself. Is all this possible! cheers
Hi, I am using the global optimization toolbox to minimize a matlab function as follows: restart; > (Matlab:-evalM)("cd 'C:/Documents and Settings/user/Maple'"); > mat2map1 := proc(a, b) local Res,res; Matlab:-setvar(\"a\",a); Matlab:-setvar(\"b\",b); Matlab:-evalM(\"result = mat2map1(a,b)\"); Res:=Matlab:-getvar(\"result\"); res:=convert(Res,float); return res; end proc; > with(GlobalOptimization): > infolevel[GlobalOptimization] := 3: > GlobalSolve(mat2map1, a = 0 .. 5, b = 0 .. 5); When I run this I get the following error message:
Hi! I am trying to convert an entire Maple worksheet into Fortran code. At the moment, I have managed to convert a specific program using with(codegen): f:=proc(x) function end proc fortran(f) But this method can only convert one function at a time. Can someone please help me to convert an entire worksheet into Fortran or other languages? I have text and math in my worksheet, and I'm using 2D math in Maple 10. Thanks :)
Is there a way to track a thread without responding to it?
I have two small questions: 1. Given a list L: L:=[false, false, true, true, FAIL,false]; and I want to get the positions of "FAIL" (in this case 5) and false (1,2,6). HOW could I get that? 2. Now, given another list Z with the same number of elements: Z:=[z1,z2,z3,z4,z5,z6]; I would like to replace the values of FAIL by 0 (zero). (in the way that Z became: Z:=[z1,z2,z3,z4,0,z6];) It is possible to do that without using "for do" commands? Thanks in advance, JJacques
Does anyone know if it's possible to discover the largest known prime number just using Maple 10 on a stand alone machine (PC)? Or does Maple 10 and or all of it's current additions / upgrades lack the computing power required to attempt this possible recreational task ? v/r, Dan
Hi dear Maple's gurus. I have the lists a and b: a:=[A, B, C] b:= [[K1,L1][K2,L2][K3,L3]] I want to add the each term of "a" in the intervals given in "b": sum(A from L1 to K1)+ ..+sum(C from L3 to K3). I tried with this procedure: > sums:= proc(a,b) local j,tot; tot:=0; for j from 1 to nops(a) do tot:=tot+sum(a[j], k=b[j,2]..b[j,1]); end do: end proc: >sums([a1,a2,a3],[[ku1,kl1],[ku2,kl2],[ku3,kl3]]); 1. Is there some more efficient way to do the same? 2. I would like also that the sums on a[j] under the following 2 join conditions: 2.1. assuming that a[j] is real and positive, and
Hi there! Assuming that I have the following fraction: fr1:= (x+1)/(x-1); I have the following 2 questions: 1. with which command could I take only the numerator "(x+1)"? (and for the denominator?) 2. Is it normal that whattype(fr1); returns a star * Thanks in advance for your answers, Jean Jacques
Simple question: I can't seem to use a negative number as a minimum value for a slider control (in Maplet Builder)... Is this not possible? Thanks! Bryan
First 2443 2444 2445 2446 2447 2448 2449 Last Page 2445 of 2457
