how could I force Maple to solve this pde
pdsolve(y*(diff(f(x, y, z, w), x))-x*(diff(f(x, y, z, w), y))+w*(diff(f(x, y, z, w), z))-z*(diff(f(x, y, z, w), w)) = 0)
When I hit enter, it happens nothing.
Matrix([[xx3[1,2],xx3[1,3]],[xx3[2,2],xx3[2,3]]])
Matrix(2, 2, {(1, 1) = (1/6)*sqrt(3)+(1/2)*I, (1, 2) = (1/6)*sqrt(3)-(1/2)*I, (2, 1) = (1/6)*sqrt(3)-(1/2)*I, (2, 2) = (1/6)*sqrt(3)+(1/2)*I})
expect output be
but these example are wrong
((1/6)*sqrt(3)+(1/2)*I)*Matrix([[1,-I].[-I,1]])
MatrixMatrixMultiply(Matrix([[(1/6)*sqrt(3),(1/2)],[(1/6)*sqrt(3),(1/2)]]),Matrix([[1,-I],[1,I]]));
concept like this output
How do you evaluate a function expression at given variable values?
f := 2*sin(x)-x^2/10.00:
eval(f, x = 5) gives 2*sin(5)-2.500000000
evalf(eval(f, x = 5)) gives -4.417848549
So is there a way we can just numerically calculate f(x) where x = 5?
Below is MAPLE code to simplify a series.  MAPLE expresses the result in terms of functions which many people are not familiar with.  Is there a way to express the answer in terms of more conventional functions expecially if N is a positive integer?
Cn := ((-I)*(1/2))*(2*(I*Pi*n*tau-(2*I)*Pi*n)*cos(Pi*n*tau/T)-T*(2*I)*sin(Pi*n*tau/T)+(4*I)*Pi*n)/(Pi^2*n^2); S4 := a[0]+sum(Cn*sin(2*Pi*n*x/T), n = 1 .. k); a[0] := 0; T := 4; tau := 2; Cn; S5 := unapply(S4, k, x); T := simplify(S5(N, x))
convert(T, StandardFunctions);
(-polylog(2, exp(-((1/2)*I)*Pi*(x-1)))*N^2-exp(-((1/2)*I)*Pi*N*(x+1))*LerchPhi(exp(-((1/2)*I)*(x+1)*Pi), 2, N)*N^2+polylog(2, exp(((1/2)*I)*(x+1)*Pi))*N^2+exp(-((1/2)*I)*Pi*N*(x-1))*LerchPhi(exp(-((1/2)*I)*Pi*(x-1)), 2, N)*N^2+polylog(2, exp(-((1/2)*I)*(x+1)*Pi))*N^2-exp(((1/2)*I)*Pi*N*(x+1))*LerchPhi(exp(((1/2)*I)*(x+1)*Pi), 2, N)*N^2-polylog(2, exp(((1/2)*I)*Pi*(x-1)))*N^2+exp(((1/2)*I)*Pi*N*(x-1))*LerchPhi(exp(((1/2)*I)*Pi*(x-1)), 2, N)*N^2+exp(((1/2)*I)*Pi*N*(x+1))-exp(((1/2)*I)*Pi*N*(x-1))+exp(-((1/2)*I)*Pi*N*(x+1))-exp(-((1/2)*I)*Pi*N*(x-1))-I*exp(-((1/2)*I)*x*Pi*N)*LerchPhi(exp(-((1/2)*I)*x*Pi), 1, N)*N^2*Pi-I*ln(1-exp(-((1/2)*I)*x*Pi))*N^2*Pi+I*exp(((1/2)*I)*x*Pi*N)*LerchPhi(exp(((1/2)*I)*x*Pi), 1, N)*N^2*Pi+I*ln(1-exp(((1/2)*I)*x*Pi))*N^2*Pi-I*exp(((1/2)*I)*x*Pi*N)*N*Pi+I*exp(-((1/2)*I)*x*Pi*N)*N*Pi)/(N^2*Pi^2)
Download simplify.mw
How can I specify curve of function  when drawing set of functions in  one plot ,( curve1, curve2,...) in Legend
When attempting to numerically solve for a function using fsolv it is possible that the function has multiple roots.  So to focus on a particular region you specify a range such as:
xmax := fsolve(S, x = 0 .. 1/2)
Is it possible fsolve may not resolve the solution due to the fact that delta x is not small enough or does fsolve autonomously adjust delta x in order to find the solution?  If not, how do you manually dictate the delta x for the interval specified?
Could you please help me with the following problem? I'm new to Maple and I need some help.
Find the real solutions of the following system(it's a nonlinear system):
x^2 + y^2 + z^2 = 4
x + y + z = 0
x*sin(y*z) = -1
Request help in solving the equation:
Eq_H_1 := C[11*m]*(int((t-(j-1)*T)*alpha*(-alpha*(K*T*beta+T*beta*j-K*T-T*beta-T*j-beta*t+T+t))^(-beta/(beta-1))*exp(-R[m]*t), t = (j-1)*T .. (K+j-1)*T))
Could you please help me with the following problem? I'm new to Maple and i need some help.
Solve the equation x^3 - a*x + 1 = 0 , in x. Determine the particular solution for a=1,2,... .Graphically represent the polynom that appears in the equation, in a case where the equation has a real root and in a case where the equation has 3 real roots.
Thank you !
I d like to limit my solution to a real (non complex) solution
There should be a simple solution to my calculation but maple can t process the solutions in one of my "solve" commands.
How can do I tell maple to limit itself to one
with(Student[Calculus1]):
#geometry [mm]
b := 250:
h := 720:
ds := 70:
d := h-ds:
As := 3000:
#concrete [MPa]
fck := 30:
fcm := fck+8;
38
Ecm := 33000;
33000
`ϵc1` := 2.2*(1/1000);
0.2200000000e-2
eta := `ϵc`/`ϵc1`;
454.5454545*`ϵc`
Ec1 := fck/`ϵc1`;
13636.36364
k := 1.05*Ecm/Ec1;
2.540999999
sigma := fcm*(-eta^2+eta*k)/(1+(k-2)*eta);
38*(-206611.5702*`ϵc`^2+1154.999999*`ϵc`)/(1+245.9090904*`ϵc`)
#steel [MPa]
Es := 200000:
fsy := 400:
fsu := 600:
`ϵy` := fsy/Es;
1/500
`ϵsh` := 0.9e-2:
`ϵsu` := 0.75e-1:
P := 4:
`ϵs` := `ϵcm`*(d-c)/c;
`ϵcm`*(650-c)/c
i := 1;
for `ϵcm` from .1*(1/1000) by .1*(1/1000) to 10*(1/1000) do `ϵs` := `ϵcm`*(d-c)/c; T[1] := `ϵs`*Es*As; T[2] := fsy*As; T[3] := (fsu+(fsy-fsu)*((`ϵsu`-`ϵs`)/(`ϵsu`-`ϵsh`))^P)*As; C := b*c*(int(sigma, `ϵc` = 0 .. `ϵcm`))/`ϵcm`; eq[1] := T[1] = C; `ϵl`[1] := `ϵy`; eq[2] := T[2] = C; `ϵl`[2] := `ϵsh`; eq[3] := T[3] = C; cc := max(solve(eq[1], c)); `ϵss` := subs(c = cc, `ϵs`); Ta := subs(c = cc, T[1]); if `ϵss` >= `ϵl`[1] then cc := max(solve(eq[2], c)); Ta := subs(c = cc, T[2]); `ϵss` := subs(c = cc, `ϵs`) end if; if `ϵss` >= `ϵl`[2] then cc := max(`assuming`([solve(eq[3], c, useassumptions)], [c::real])); Ta := subs(c = cc, T[3]); `ϵss` := subs(c = cc, `ϵs`) end if; M[i] := b*cc^2*fcm*(int(sigma*`ϵc`, `ϵc` = 0 .. `ϵcm`))*10^(-6)/`ϵcm`^2+T*(d-cc)*10^(-6); phi[i] := `ϵcm`/cc; cd[i] := cc/d; print(`ϵcm`, `ϵss`, Ta/As); i := i+1 end do
0.1000000000e-3, 0.1955232439e-3, 39.10464877
0.2000000000e-3, 0.3845102290e-3, 76.90204580
0.3000000000e-3, 0.5671741821e-3, 113.4348364
0.4000000000e-3, 0.7437144096e-3, 148.7428819
0.5000000000e-3, 0.9143174400e-3, 182.8634880
0.6000000000e-3, 0.1079158043e-2, 215.8316087
0.7000000000e-3, 0.1238400148e-2, 247.6800297
0.8000000000e-3, 0.1392197667e-2, 278.4395334
0.9000000000e-3, 0.1540695238e-2, 308.1390476
0.1000000000e-2, 0.1684028897e-2, 336.8057793
0.1100000000e-2, 0.1822326682e-2, 364.4653363
0.1200000000e-2, 0.1955709188e-2, 391.1418377
0.1300000000e-2, 0.2226921078e-2, 400
0.1400000000e-2, 0.2583745185e-2, 400
0.1500000000e-2, 0.2954159196e-2, 400
0.1600000000e-2, 0.3336139462e-2, 400
0.1700000000e-2, 0.3727768551e-2, 400
0.1800000000e-2, 0.4127227927e-2, 400
0.1900000000e-2, 0.4532791280e-2, 400
0.2000000000e-2, 0.4942818378e-2, 400
0.2100000000e-2, 0.5355749454e-2, 400
0.2200000000e-2, 0.5770100024e-2, 400
0.2300000000e-2, 0.6184456101e-2, 400
0.2400000000e-2, 0.6597469817e-2, 400
0.2500000000e-2, 0.7007855358e-2, 400
0.2600000000e-2, 0.7414385220e-2, 400
0.2700000000e-2, 0.7815886744e-2, 400
0.2800000000e-2, 0.8211238846e-2, 400
0.2900000000e-2, 0.8599369121e-2, 400
0.3000000000e-2, 0.8979250971e-2, 400
Error, complex argument to max/min
`ϵcm` := 0.35e-2; `ϵs` := `ϵcm`*(d-c)/c; T[1] := `ϵs`*Es*As; T[2] := fsy*As; T[3] := (fsu+(fsy-fsu)*((`ϵsu`-`ϵs`)/(`ϵsu`-`ϵsh`))^P)*As; C := b*c*(int(sigma, `ϵc` = 0 .. `ϵcm`))/`ϵcm`; eq[1] := T[1] = C; `ϵl`[1] := `ϵy`; eq[2] := T[2] = C; `ϵl`[2] := `ϵsh`; eq[3] := T[3] = C; cc1 := max(solve(eq[1], c)); `ϵss1` := subs(c = cc, `ϵs`); Ta1 := subs(c = cc, T[1]); cc2 := max(solve(eq[2], c)); `ϵss1` := subs(c = cc, `ϵs`); Ta2 := subs(c = cc, T[2]); cc3 := max(solve(eq[3], c)); `ϵss3` := subs(c = cc, `ϵs`); Ta3 := subs(c = cc, T[3]); M[i] := b*cc^2*fcm*(int(sigma*`ϵc`, `ϵc` = 0 .. `ϵcm`))*10^(-6)/`ϵcm`^2+T*(d-cc)*10^(-6); phi[i] := `ϵcm`/cc; cd[i] := cc/d; print(`ϵcm`, `ϵss`, Ta/As); i := i+1
7501.663386*c
308.9753080
0.1055633997e-1
6333803.979
159.9645223
0.1055633997e-1
1200000
0.1055633997e-1
1254623.652
0.35e-2, 0.9349901112e-2, 400
Download mathias.mw
simple non complex solutions ?
Hey mapleprimes
I am trying to get the sum function to give me n variables, well not sure how to explain it, so let me show:
sum(x__i, i = 0 .. 2)
I was expecting to get x__0 + x__1 + x__2
But instead i got:   3*x__i
Thanks for the help in advance :)
Edit:
My problem is gone, but must be some weird character that is playing games with me or something
I m trying to do a nested loop but for some reason maple tells me my for loop is unterminated
I d love some feedback on my code and on how to make it work
#geometry [mm]
b := 250:
h := 720:
ds := 70:
d := h-ds:
As := 3000:
#concrete [MPa]
fck := 30:
fcm := fck+8;
38
Ecm := 33000;
33000
0.2200000000e-2
eta := `ϵc`/`ϵc1`;
454.5454545*`ϵc`
Ec1 := fck/`ϵc1`;
13636.36364
k := 1.05*Ecm/Ec1;
2.540999999
#steel [MPa]
Es := 200000:
fsy := 400:
fsu := 600:
`ϵy` := fsy/Es;
1/500
`ϵsh` := 0.9e-2:
`ϵsu` := 0.75e-1:
P := 4:
`ϵcm`*(650-c)/c
i := 1;
"for epsiloncm from 0.1/(1000) by 0.1/(1000)to (3.5)/(1000) do  print(epsiloncm);     epsilons:=(epsiloncm)/(c)*(d-c):  T[1]:=epsilons*Es*As:  T[2]:=fsy*As:  T[3]:=fsu+(fsy-fsu)*((epsilonsu-epsilons)/((epsilonsu-epsilonsh)))^(P):  T[4]:=0:  C:=(b*c)/(epsiloncm)*int(sigma,epsilonc=0..epsiloncm):  eq[1]:=T[1]=C:  epsilonl[1]:=epsilony:  eq[2]:=T[2]=C:  epsilonl[2]:=epsilonsh:  eq[3]:=T[3]=C:  a:=1          for j from 1 by 1 to 3 do          if a=1 then          cc:=max(solve(eq[j],c)):          epsilons:=subs(c=cc,epsilons):          if epsilons<=epsilonl[j] then T:=subs(c=cc,T[j]): a:=0:          end if:          end if:          end do:  M[i]:=(b*cc^(2)*fcm)/(epsiloncm^(2))*int(sigma*epsilonc,epsilonc=0..epsiloncm)*10^(-6)+T*(d-cc)*10^(-6):  phi[i]:=(epsiloncm)/(cc):  T[i]:=T:  cd[i]:=(cc)/(d):    print(M[i],epsiloncm,phi[i]);  i:=i+1:  end do:                                        "
Error, unterminated loop
"for epsiloncm from 0.1/1000 by 0.1/1000to 3.5/1000 do  print(epsiloncm);     epsilons:=epsiloncm/c*(d-c):  T[1]:=epsilons*Es*As:  T[2]:=fsy*As:  T[3]:=fsu+(fsy-fsu)*((epsilonsu-epsilons)/(epsilonsu-epsilonsh))^P:  T[4]:=0:  C:=(b*c)/epsiloncm*int(sigma,epsilonc=0..epsiloncm):  eq[1]:=T[1]=C:  epsilonl[1]:=epsilony:  eq[2]:=T[2]=C:  epsilonl[2]:=epsilonsh:  eq[3]:=T[3]=C:  a:=1         for j from 1 by 1 to 3 do          if a=1 then  cc:=max(solve(eq[j],c)):  epsilons:=subs(c=cc,epsilons):          if epsilons<=epsilonl[j] then T:=subs(c=cc,T[j]): a:=0:          end if:          end if:          end do:  M[i]:=(b*cc^2*fcm)/(epsiloncm^2)*int(sigma*epsilonc,epsilonc=0..epsiloncm)*10^(-6)+T*(d-cc)*10^(-6):  phi[i]:=epsiloncm/cc:  T[i]:=T:  cd[i]:=cc/d:  print(M[i],epsiloncm,phi[i]);  i:=i+1:  end do:                                        "
Download mathias.mw
Please help me to solve this system of equations.
Download System.mwSystem.mw
Hi everyone,
I have to make a project that need to use openmaple in java. The problems is when i get the output data of the textCallBack method, i try to convert the output to utf-8 format using the UTF8Encoder provided in java Maple JAR file in order to display Vietnamese language but it doesn't work (the output type is String). Are there any solutions? Thank you.
Hi everybody,
I have two questions about DataSummarize when used with "summarize=embed"
  1. Is it possible to set the width of the table DataSummarize returns ?
    (I thought DataSummarize used DocumentTools[Tabulate] but the option "width=..." doesn't work)
  2. Is it possible to save this table programmatically (for instance in a jpeg file) ?
First 933 934 935 936 937 938 939 Last Page 935 of 2470
