when i am trying to isolate for Rev in the following expression
the program doesnt respond.do you know why?
I have a vector of dimension n with each component being an equation of a linear system.
Can maple convert this Vector to a Matrix-Vector form with the matrix being constant coefficients?
Hi all.
Assume that we have partitioned [0,a], into N equidistant subintervals and in each subinterval we have M sets of poly nomials of the following form:
where Tm(t)=tm( namely Taylor Series) and tf is a(final point)
for Example with N=4, M=3 we have:
now we want to approximate a function, asy f(t), in this interval with following form:
Assume that we have
where '"." means common derivetive. How can we do the later integran in right way?
Note that t is unknown
Mahmood   Dadkhah
Ph.D Candidate
Let B is a list of polynomial conditions such that  are none zero. Consider one polynomial f. How can I detect that f is none zero w.r.t. B? For example if B=[a-1,b+2,b-c,ac-1] and f=a^2c-ac-a+1. From B we can conclude that a<>1 and b<>2 and b<>c and ac<>1. How can I deduce that f<>0 w.r.t. B automatically?
I have been trying to plot Riemann Zeta Function on certain range, but it takes a lot of time(several minutes ,maybe hours).These are the basic things.
How to speed up ploting Zeta?
The same problem with Optimization.
Zeta-Problems.mw
Mathematica don't have this such problems.
Mathematica ploting Zeta with 0.125 second and optimizing 3.42 second.Maple few hours maybe......
I want to make a for loop inside another loop, but this code does not seem to work well.
for i from 0 to 10 do
  for n from 0 to 10 do
  i+n
  end do
How would I find inflection points? I believe it would the same as if I was finding critical points for f '.
Function is:(7-x)*sin(x^2-7)
So would it be:
a:=fsolve(f2,-2.4..2.4);
b:=fsolve(f2,-2.4..-0.06);
c:=fsolve(f2,-0.06..2.4);
d:=fsolve(f2,1.49..3);
e:=fsolve(f2,-3 ..-1.52);
Plz and thanks!
I am a new use of Maple. I have a expression :
2.560000000*10^(-30)*k1*(2.309486127*10^38*n-1.154743064*10^38-1.186994552*10^37*k2^2*n^2+2.373989104*10^37*k2^2*n+8.541613702*10^37*k2*n^2-1.154743064*10^38*n^2+7.119519043*10^37*n^2*k1^2+6.495962587*10^37*k1*n^2-1.293058266*10^38*k2*n^2*k1-1.186994552*10^37*k2^2-1.708322740*10^38*k2*n+1.293058266*10^38*k2*n*k1+8.541613702*10^37*k2-3.529088273*10^37*k1-2.966874313*10^37*k1*n)/(1.620847396*10^9*n-1.620847396*10^9)
I want to simplify it. Obviously, it can be simplifed by simplifying the coeffecient of each terms.
When I use 'simplify' command in Maple 18, I couldn't got what I want.
Any suggetstions?
  I have the following input
with( Statistics ):
a:=2;c:=0.3;
g:= exp(-a*x) + c*a*exp(-a*x);
#f := x -> piecewise( x < 0, 0, x>0, g );
 f :=x -> piecewise( x < 0, 0, x>0, exp(-a*x) + c*a*exp(-a*x));
norm_factor:=int( f(x), x=0..infinity );
print(norm_factor);
randomize():
F := Distribution( PDF = 1/norm_factor*f ):
X := RandomVariable( F ):
N := 20;
S := convert( Sample(X,N), list );
print(`cc`,S[1]);
The code works. However, if I comment out
 , then use
i.e.
 #f :=x -> piecewise( x < 0, 0, x>0, exp(-a*x) + c*a*exp(-a*x));
It is said "
Error, (in Statistics:-Sample) unable to construct the envelopes for _R, try to specify the initial range"
The norm_factors are actually the same for both inputs. What is the reason for the error message?  Suppose I still want to use something like
,how to fix the problem?
Thank you very much
I'm drawing a complete blank on this.
The probability of a branch breaking in a particular tree as someone climbs is 2%.  After the person has climbed over 40 branches, did any of them break?  I'm trying to set that up as a simulation in Maple but I'm not sure about how to do it.
I guess if I generate a random number and it falls under .02 it breaks, is that how I determine that?
randomize():
n := 0;
for i to 40 do
ran := evalf(rand()*10^(-12));
if ran < 0.2e-1 then n := n+1: end if:
print("Branch broke", n, "times")
I'm not sure I've got the probability right.
Shading is not valid as an option in the command defining a plottools object e.g. a parallelepiped, and yet shading can be selected in the actual display of the object. Is there a way to code for shading when creating the object?
Ive been trying to solve critical points for maple but i keep getting this werid equation:
(1/7)*RootOf(tan(_Z)^2+4*_Z*tan(_Z)+4*_Z^2+28*tan(_Z)-140*_Z-1176)+1+(1/14)*tan(RootOf(tan(_Z)^2+4*_Z*tan(_Z)+4*_Z^2+28*tan(_Z)-140*_Z-1176)).
What I have typed
f:=x->(7-x)*sin(x^2-7);
f1:=D(f);
When I try putting:
solve(f1(x)=0);
I get that werid equation
Can I make a button with the code so it will execute the entire worksheet?
I have tried without sucess to run the
Equation manipulator.
I get the following error:
Error, (in Maplets:-Tools:-CleanElements) invalid input: op expects 1 or 2 arguments, but received 0
Do I have to load some package for it to run?
I have searched for a solution but can not find one.
Getting desperate.. anyone?
TIA
LWc
I want write loop for this code:
V := 24;
eq := {Eq2, Eq3};
ans := fsolve(eq, {a1 = 0, a3 = 0});
r := 0;
W1 := rhs(ans[1])*phi11(r)+rhs(ans[2])*phi21(r)
V and W1 is Variable, I change V and solve eq and determinen a1 and a3 after i calculated W1
I want write Loop for this,
can you help me????????/
First 1218 1219 1220 1221 1222 1223 1224 Last Page 1220 of 2430
