I seem to have an error or maybe two when I use dsolve and I've traced it back to my defining functions.  I know I'm probably not defining something the right way.
a:=m*(diff(x(t), t,t))+beta*(diff(x(t), t))+m*9.8*(f'(x)/(1+(f'(x)^2)))
f:=x->sin(x)
de:=a=0
m:=0.01;beta:=0.01;
                           m := 0.01
                          beta := 0.01
with(Physics):
ic:=x(0)=0,D(x)(0)=.5;
sol:=dsolve({de,ic},x(t),numeric)
                        Error, (in dsolve/numeric) x(t) and x cannot both appear in the given ODE
differential_test.mw
hi every one..
how i solve numerically  couple equations which attached below .in solve this equation we must  starting from a very small value of V(voltage) with initial guesses for x1 and x3
near zero and using find root method.it is noted that  the solution at this voltage step are used as initial guesses
for the next voltage step, and the process is repeated..
2DOF.mw
My 5 year old laptop executes some commands very slowly e.g. plottools(rotate) around a line which is not a Cartesian axis. I intend to buy a new desktop. Which off-the-shelf desktops provide the fastest processing of Maple commands which do not include large data sets? Which provide the best price/performance?
I have this task which says:
Find the equation of the tangent for the function: f(x)= -ln x + ex P(2,f(2)).
So, I first defined the function in Maple: f(x):=-ln(x)+(e)^(x)
then I wrote the equation of the line which is: y = f(2)*(x-2)+f(2)
BUT it does not work! Help me plzzzz
The following code works fine:
with(LinearAlgebra): with(MTM): with(StringTools): MultivariateNormalSample := proc (Sigma, V, N) local d; d := LinearAlgebra:-Dimension(V); LinearAlgebra:-LUDecomposition(Matrix(Sigma, datatype = float[8]), 'method' = 'Cholesky') . ArrayTools:-Alias(Statistics:-Sample(Normal(0, 1), d*N), [d, N])+ArrayTools:-Replicate(Vector[column](V, datatype = float[8]), 1, N) end proc: S := MultivariateNormalSample(`<,>`(`<|>`(1, 2), `<|>`(2, 5)), `<,>`(2, 3), 100):
W := ~int8(~round(S)):
K := convert(W, string):
K := Drop(K, 17):
K := Select(IsDigit, K):
M := seq(PadRight(K[i], 2), i = 1 .. Length(K)):
Z := M[1]:
for i from 2 to Length(K) do Z := cat(Z, M[i]); if `mod`(i, 2) = 0 then Z := cat(Z, "\n") end if end do:
Z;
but if I make a proc out of it then it breaks down on the line:
There seems to be an issue with the elementwise tilde operator.
Generate:=proc()
local MultivariateNormalSample,S,W,K,M,Z,i;
K := Drop(K, 17):
Z := M[1]:
return Z:
end proc;Generate();
I seem to have missed something. Any ideas?
Harry
hi.please see attached file and explain how i remove error
thanks alot
error3.mw
Maple 2015, Windows 7 Pro
Notice the printout of the following example.  The true/false Maple evaluations are incorrect because I do not know what TYPE command to put in the printf expression.  However, the format of the printout is what I want.
r:= [17=15,16<17,17>18]:
printf("%{}9a\n\n%{}9a\n\n", <r>,<type~(r,anything)>)
  17 = 15   16 < 17   18 < 17
     true      true      true
In this second example the Maple evaluations of the statements are correct, but I want the print format to flow accross the page rather than down the page.
for r in [17 = 15, 16 < 17,18 < 17]
do
printf("%{}9a\n\n%{}9a\n\n",<r>,<evalb(r)>)
  17 = 15
  16 < 17
  18 < 17
Could someone show me how to modify the second example so that the printout will flow across the screen rather than down the screen.  Thanks in advance, Les  PS I'd like to keep the loop if possible.
I have y"+y=sinx
If I want to substitute y=sinx, how should I do it?
I tried subs(y=sin(x),f(y))(ofc after defining f:=y as above).
The most troubling thing is that it does not automatically apply double derivative.
I have the following code of a plot:
plot(
add(BS(bb[4], t, i, 3)*bb[1](i+1), i = 0..n),
add(BS(bb[4], t, i, 3)*bb[2](i+1), i = 0..n),
t = 0..1
color=red, axes=normal, scaling=constrained, numpoints=100, thickness=2
and I get the following error:
Error, (in BS) cannot determine if this expression is true or false: 0 <= t and t < .54901960784313725490196078431373
The problem is that, in the definition of BS, there are some conditions that depend on the variable t. It seems that Maple does not use a specific value of t when executing BS. My solution is to plot specific points, i.e.,
plot(
seq([add(BS(bb[4], h/5000, i, 3)*bb[1](i+1), i = 0..n),
add(BS(bb[4], h/5000, i, 3)*bb[2](i+1), i = 0..n)], h=0..5000)
Can this be done in a more elegant way?
Hello maple experts,
please is there any other way of solving this problem Wht.mw
Some complained that the graphs do not satisfy the boundary conditions smoothly.
How can I display in Maple T.A. the content of a matrix as pure text?
Thus instead of
matrix([[1, 2], [3, 4]])
1 2
3 4
Is there a solution without using Mathml and hopefully without using StringTools?
And can I assign the rectangular text display to a variable (including line feeds)?
Harry
Dear Friends
I am trying to find determining system for variable coefficient KdV equation, this system is required to find relevant point symmetries for said equation. Following is set of command that I used to perform task:
This last cammand gives me determining system for PDE1.
Following is direct procedure to find determining system:
This last command give large expression from which determining system is obtained by equating coefficient to zero which does not matches with determining system obtained with first procedure.
What could be the possible error?
I have also attached relevant Maple18 file for analysis.
[411]_Determing_Equations_for_Variable_coefficient_KdV.mw
Here is one I have been struggling with lately:
I have a relatively large module with many procedures inside (plus some other data structures). In one of the procedures, it turns out that it would be convenient to have a subprocedure defined inside to both shorten the code by avoiding duplication as well as make it more error proof (once the subprocedure is debugged it'll be correct everywhere it is used). Here is the skeleton
Lattice:=module() option package;
export Track;   ...
   Track:=proc(arguments) uses LinearAlgebra;
   local trackElement;
      for ... do
         result:=trackElement(parms); # This does not work
      end do
      trackElement:=proc(arguments) uses LinearAlgebra;
      end proc; # trackElement
   end proc; # Track;
end module; # Lattice
The problem I have is that procedure trackElement is not recognized as i found out running the code in the debugger. I can make it work by taking trackElement out of Track and make it local to the Lattice module. While functionally this works (and it is how I have it now programmed), I do  not like it as every proc in the Lattice module can see trackElement. That should not be so, I want it local to procedure Track, which is where it belongs.
I really thought I could define procedures within procedures. Am I wrong? Or is there something else ging on?
TIA,
Mac Dude
PS: The whole module is more than 100 kB of Maple code sitting in a library. I refrain from uploading it here as it would be non-trivial to get going even for a simple test case.
So basic problem.
I want to create a list with undetermined size. I have some data, let's say these data objects are numbers for now (they can be expressions of variables, or even equations)
Here is a pseudocode,
for n=1:10
  list(n) = n+1;
end
So the above for loop will create a list of size 9, with objects being number 2 through 11.
I want the list to be in {} form
Now I awnt to take this further. Let's say my data objects aren't just numbers, but expressions. How would I create a list of expressions and turning them into an equation?
Example
e1 := a^2 + b
e2 := b + a*b
e3:= b*a + a*b^2
Pesudocode
for i = 1:3 do
list(i) = ei ~=0;
end
Output should look like
list = {a^2 + b = 0, b + a*b=0,b*a + a*b^2=0}
Notice the use of curly braces
First 1229 1230 1231 1232 1233 1234 1235 Last Page 1231 of 2430
