I googled everywhere for this and most results just tell me what diff and D does...
Basically I have a function, let's say
f:= x -> x^2
How do I turn the derivative of f into a function?
I tried
fprime := x -> diff(x^2,x)
But tihs just shows me diff(x^2,x), instead of x -> 2x
Starting with Maple 18, the Print to PDF feature caused the document page to be hard-aligned at the left margin of the page. Maple 2015 still seems to have this problem / bug.
Does anyone else have the same problem? Has a work-around been posted? Is a fix in the works after nearly 9 months?
JJW
WHen I type:
I get nothing, a blank box. But if I change the code slightly, by squaring both sides, then it works.
What is the reason for this. I uploaded an image of the output:  http://prntscr.com/752mtd
Hi. I am having trouble with maples command "Cross product", i don't know why it doesn't work. Can anybody help me? This is a screenshot of the problem:
How to find the determining equation for a system of fractional differential equation using Maple 15?
This question is 99% similiar to an previously posted question, but this one has a little twist(s).
http://www.mapleprimes.com/questions/200101-Solving-For-Coefficients-Of-Polynomial-Equations
Here is the sample problem. Let's say I have the following equations
e1:=(a+b+1)x^2 + (a+1)*x^4 = 0;
e2:=(a-b)*x+ (a^2 - 1)*x^3 = 0;
One can immediately tell the system is inconsistent because on x^3, we have a = -1,1 but on x and x^2 we have a = -1/2
This is precisely the problem I am facing, my e1 and e2 will eventually get bigger (bigger as in the order of the polynomial will increase) and I keep facing inconsistencies.
However if I could find a way to code it so that I can ask Maple to solve only up to a certain degree it would be great. This will eliminate any inconsistency
For example, using the system I have here, the system is consistent up to order 2 (it will always start from constants and up to a certain power). So I will ask Maple to solve the above system up to order 2.
Here is a pseudocode I have been working on.
For i = 1..2 //this might be increased, but it will of course be finite and probably won't go past 10.
For j = 0..N
//N is the degree of polynomial
f[i]:= coeff(e[i],x,j);
end
end
//the above generates the equations, below will solve it
solve( { f[i], i=1..?} ,{a,b})
Note that the pseudocode assumes e[i] are expressions and not equations set to 0 (which is what I have). Is there an "un"unapply on maple?
edit1: have to sleep  (late where I am! Will check for responses tomorrow) thank you
In a local coordivates frame {B}, an arc whith center "coc" ,radius "radius" and angle between “alpha1” and “alpha2” can be plotted in XY plane of {B}. The coord {B} is in a Ref frame {O}. The homogeneous transformation matrix is “H”. How can I plot this arc in coordinate {O}?
solve 30a+75b+110c+85d+255e+160f+15g+12h+120i=800000 over the positive integers
how to export a plot with its points  (x,y) from maple to excel
Hello Everyone
I am new to Maple and I have to find the determinant of the following matrix
Matrix comprising of Bessel Functions whose determinant is to be calculated
https://drive.google.com/file/d/0B_60Jre5scdoSTJ3WUVaMUlidzA/view?usp=sharing
Here k is a constant.
Can you please help me with it.
g:=Groebner:-Basis([a-2.0*b,b-2], plex);
Groebner:-Reduce(a, g, plex);
Error, (in content/polynom) general case of floats not handled
How to solve this problem simply?
now the equation is
d2u/dt2-(2*d2u/x2)+d2u/dxdt=0
initial condition: u(x,0)=1-(xsign(x)), abslute x<1,0 otherwise. Assume sign(x)=-1 for x<0, 1for x>0
 Ut(x,0)=cos(pix), bslute x<1, 0 otherwise , he didnt give any B.Cs
so I would like to know the analytical and numerical sols, and plots for the wave at t=2,4
for Numerical:   delta x=0.1, delta t=0.025, range 0..4
Please how can Maple plot both analytic and numerical solutions on the same axes for this problem Ana_Nume.mw
U(x,t)= 2/3f(x+t)+1/3f(x-2t)+(1/3pi)(sin(pi(x+t))+(1/3pi)(sin(pi(x-2t)),
f(x)=1-x,abslutex<1, zero otherwise
I am trying to plot sequence like:
arrayZ[1]:=NULL;
arrayZ[2]:=5;
arrayZ[3]:=NULL;
arrayZ[4]:=NULL;
arrayZ[5]:=8;
arrayZ[3000]:=1111;
data:=[seq([n,arrayZ[n]], n=1..3000)]:
t1:=plot(data, style=point, symbol = solidcircle, color= red):
plots[display]({t1});
but get incorrect first argument error. How to fix this?
PS. In original sequence instead of null I have constant value, but I don't want it in my plot.
First 1274 1275 1276 1277 1278 1279 1280 Last Page 1276 of 2430
