how to convert between (system of polynomials or module) and rational function which is a four dimensional space
1. is module in algebraic geometry or group cohomology to classify homology group?
2. is final result like this? for example,
a dictionary  or table store
homology group 1, key=invariant = 1 hole in topological space , value = module 1, module 2 module 3 etc
homology group 2, key=invariant = 2 holes in topological space , value =module 4, module 5, module 6 etc
homology group 3, key=invariant = 3 holes in topological space , value = module 7, module 8.. etc
 ... etc
3. i find betti number can count holes, however how to know the form for
all combination?
i mean if it is module, how to change the module to get the full combination
http://www.singular.uni-kl.de/Manual/html/sing_159.htm
i find betti number's input is just ideal, but it is not module
if ideal is enough, why need module?
how to permuate module? and what do it classify and result in module?
1. is module in algebraic geometry for classification of topological space which a poset is a frame
2. which invariant is for doing this classification of topological space in algebraic geometry or group cohomology?
3. if want to do full combination before classification, which kind of polynomials be a full combination
4. is poset just like function fst and snd function for meet and join in functional programming instead of using "and" and "or" logic? how a matrix group related with topological space which a poset is a frame?
5. is there any invariant function for classification of topological space in maple?
I am working on fopurier analysis and below is what I have. The method I used worked fine when I had a piecewise continuous function, but now the bottom int function below is not calculating the integral.
f := 2*sin(Pi-Pi*exp(-t))
A[0] := (1/3)*(Int(f, t = 0 .. 3))
A[0] := (1/3)*(int(f, t = 0 .. 3))   I think this one is evaluating it correctly. The bold and italicized below is the answer from this calulation
A[0] := (2/3)*Si(Pi)-(2/3)*Si(exp(-3)*Pi)
a[n] := (2/3)*(Int(f*cos(2*Pi*n*t*(1/3)), t = 0 .. 3))  this prints the integral like I want it to.
a[n] := (2/3)*(int(f*cos(2*Pi*n*t*(1/3)), t = 0 .. 3))  this just reporints the integral, I want it to evaluate it. Am I doing something wrong? Even with the assume(n, integer); it still just prints the integral.
Is there any help that y'all can provide? My professor is not ver proficent in the Math softwares out there.
how to write a^tilde , a^check on maple
thank,
Gerard.
How about this equation
solve(x^2 - 2*(m+1)*x+m^2 - 2*m + m^2=0,{x},parametric=full);
allvalues(%);?
Greetings to all!
Recently I encouter the following issue:
Maple (version 17) coudn't recognize that 20.0 equals with 20 and with 20.00. Believe me, this is very annoying!
Do I miss something? Is there any command that do the trick?
Giorgos K.
   I have a set of linear equations in terms of Ax+B=0, where A and B are matrices.
  I used linsolve or LinearSolve to solve the equations.
   Is there any simple way to run linsolve/LinearSolve parallelly? suppose I already have matrices A and B.
Thank you very much
#page 320 and 322 of book Singular introduction to commutative algebra
it return too many recursion
hilbertseries([a+a*c, a+a*b, a+b+c]);
eq1 := a+a*c;
eq2 := a+a*b;
eq3 := a+b+c;
eq1a := Homogenize(eq1, h);
eq2a := Homogenize(eq2, h);
eq3a := Homogenize(eq3, h);
T3:=lexdeg([a,b,c,h]);
GB := Basis([eq1a,eq2a,eq3a], T3); #a
#MonomialHilbertPoincare(LeadingMonomial(GB[1],T3), LeadingMonomial(GB[2],T3), LeadingMonomial(GB[3],T3));
with(PolynomialIdeals):
MonomialHilbertPoincare := proc (I3)
#I3:=[LeadingMonomial(GB[1],T3), LeadingMonomial(GB[2],T3), LeadingMonomial(GB[3],T3)];
T2:=lexdeg([h,c,b,a]);
varj := [h,c,b,a];
I2 := InterReduce(I3, T2);
s := nops(I2);
if I2[1] = 0 then return 1 end if:
if I2[1] = 1 then return 0 end if:
if degree(I2[s]) = 1 then return (1-varj[1])^s end if:
lt := LeadingTerm(I2[s],T2);
leadexp := [degree(lt[2],h),degree(lt[2],c),degree(lt[2],b),degree(lt[2],a)];
j := 1;
for z from 1 to nops(leadexp) do
                if leadexp[j] = 0 then
                                j := j + 1;
                end if:
finallist := [];
for z from 1 to nops(GB) do
                finallist := [op(finallist), GB[z]+varj[j]];
quotientlist := Generators(Quotient(GB, varj[j]));
finallist2 := [];
for z from 1 to nops(quotientlist) do
                finallist2 := [op(finallist2), op(z,quotientlist)];
return MonomialHilbertPoincare(finallist) + varj[1]*MonomialHilbertPoincare(finallist2);
F:=[LeadingMonomial(GB[1],T3), LeadingMonomial(GB[2],T3), LeadingMonomial(GB[3],T3)];
MonomialHilbertPoincare(F);
but if restart the program,the menu of Plot Builder is appear,in same function(x^2+y^2+(1/1000000000)*z-25 = 0),why thing like this happen?
when run the order like this, the menu of Plot builder disapper
Thank you in advance for your help
I was wondering how I could assign small angel assumptions so that I could simplify an equation of motion to solve for theta double dot. Thank you for your help.
Download small_angle_assumption.mw
Equation Manipulation
-assumptions- small angel
"sin(`ϑ`):=`ϑ`"
`ϑ`
"cos(`ϑ`):=1"
diff(`ϑ`(t), t) := 0
diff(x(t), t, t) := (H+u)/M
I*(diff(`ϑ`(t), t, t)) = [m*(-l*(diff(`ϑ`(t), t))^2*cos(`ϑ`)-l*(diff(`ϑ`(t), t, t))*sin(diff(`ϑ`(t), t)))-m*g]*l*sin(`ϑ`)+[m*(l*(diff(`ϑ`(t), t))^2*sin(`ϑ`)-l*(diff(`ϑ`(t), t, t))*cos(diff(`ϑ`(t), t))+diff(x(t), t, t))]*l*cos(`ϑ`)
Error, (in isolate) unable to isolate diff(diff(`ϑ`(t), t), t)
with(Groebner):
eq1 := a+b*c;
eq2 := a*b*c+a;
eliminate([eq1a,eq2a], h);
after eliminate not equal to eq1 and eq2
How can I pde with maple?please explain completely,and other question :How can I solve pde with plot in maple because some questions dont have exact answer?
if DegreeLexicographic is T2:=lexdeg([a,b,c],[x,y,z]);
DegreeReverseLexicographic = T2:=lexdeg([c,b,a],[z,y,x])  ?
quotientlist := Quotient(GB, varj[j]);
finallist2 := [];
if
there are only 3 monomials in quotientlist, but nops return 6
First 1378 1379 1380 1381 1382 1383 1384 Last Page 1380 of 2429
