let A be a matrix=
[  7        7      9    -17
   6        6      1    -2
 -12    -12    -27    1
   7       7      17   -15 ]
What is the reduced row echelon form of A?
What is the rank of A?
A consistent system of linear equations in 14 unknowns is reduced to row echelon form. There are then 10 non-zero rows (i.e. 10 pivots). How many parameters (free variables) will occur in the solution?
I failed to solve the ODE system shown as follows, where y1(x) and y2(x) are functions of x, ranging from -L/2 to L/2. All the other parameters are constants (A,B,C,F,G). The analytic or numeric solution of y1(x) and y2(x) are wanted.Really appreciate for you experts' help and time!!!
dsys:={diff(y1(x),x$2)-A*x^2*y1=B*diff(y2(x),x$3),diff(y2(x),x$2)-C*diff(y1(x),x)=F*x^2+G}
boundary conditions:y1(0)=0, diff(y2(L/2),x$2)=0, D(y2)(0)=0, y2(L/2)=0
RandomCompositions:= module()
local
Compositions, Rand,
local
Compositions, Rand,
ModuleApply:= proc(n::posint, k::posint)
local C;
Compositions:= [seq(C-~1, C= combinat:-composition(n+k, k))];
Rand:= rand(1..nops(Compositions));
()-> Compositions[Rand()]
end module:
R:= RandomCompositions(8,6):
seq(R(),i=1..10);
[0, 0, 2, 6, 0, 0], [1, 0, 0, 3, 4, 0], [0, 3, 3, 2, 0, 0],[1, 2, 4, 0, 1, 0], [0, 4, 0, 1, 3, 0],
[2, 0, 1, 4, 1, 0],[2, 0, 1, 1, 3, 1], [1, 0, 4, 2, 1, 0], [1, 3, 0, 2, 0, 2],[2, 0, 3, 2, 1, 0]
with(Statistics):
Tally(R());
[0 = 1, 1 = 4, 4 = 1]
I want to count the 0 to 8 respectively summation,and divide by i.
 But the  seq command  R() isn't conform  with Tally command R() .
Greetings
I am left wondering why evalf as well as right clicking and selecting approximate both are in error.
Try 1/2*sqrt(109) and find a solution with 5 digits (english isnt my first language so the wording may not be correct).
If you calculate it as 1/2*sqrt(109.0) you correctly get 5.2202
However, if you use evalf(1/2*sqrt(109)) or 1/2*sqrt(109) then right click and approximate with 5 digits you incorrectly get 5.2200.
I assume this is because both incorrectly round to 5 digits on sqrt(109) before dividing by 2 - a common mistake for very inexperienced students but surely not something I would expect from Maple.
Please explain and better yet fix. Thanks.
i'm going to solve the two eq. and plot the answer point
i try to do two group but the first succeed the second get some wrong
the first i named 1 ,and second named 2 as below
the 1 plot the correct point that i want
Although the 2 solve eq too but it didn't plot the point on(-0.36,0.29),
the code of this two is same ,
anyone can help me?
1.mw
2.mw
Hello.
I am trying to extract all the coefficients of a linear equation by calling coeffs function.
eq := 1.2*a[2]+1.3*a[3]+1.1*a[1]+1.0
vars := [seq(a[i], i = 1 .. 3)]
[a[1], a[2], a[3]]
coeffs(eq, vars)
1.0, 1.2, 1.3, 1.1
I expected I receive the coefficients in the same order as in vars variable, but I was wrong. How to extract coefficients in the order I need?
Download test.mw
in Kurzweil und Stellmacher "Theorie der endlichen Gruppen" page 97, Exercice 3 I have read
Is G nilpotent then G is cyclic.
I have found that if G is nilpotent it must not be cyclic.
Can anybody tell me whether I am right or not?
Best Regards
Kurt Ewald
Is there a way to open a classic worksheet in macintosh, even running windows through a virtual machine?
Hi there
I'm working with maple 13 (2d input) and I would like to hide the input in a worksheet, as follows:
view > show/hide contents > (unchecking) input
however i want to insert comments as text that will remain in my worksheet. Using '#' doesn't help, coz they get hidden too.
Couldn't sort out how to do this, any tips?
cheers
cilrcle.mw
i want to plot a circle which is centered at(0,0),and the radius is the length of Point2 and origin
but it shows some error,how could i do to solve this
cilrcle.mw
i want to plot a circle with that centered at (0,0),and the radius is the length of Point2 and orgin
but it shows the error
color.mw
how can i do if i  want to change the color of point1 which is rotated from point2
i want to make point2 red , and point1 is black , but the point1 is still  red
anyone can help me? thx
Hello People in mapleprimes,
I want to know how to factor the denominator of the first term in the right hand side, using commands not clickable math.
And, I know applyop can be used in this case, but I want to know is other ways than using applyop.
-tau*alpha*sigma*omega*(tau-omega^(-sigma))/(s*L*(1-gamma-tau^2+tau^2*gamma))
-(sigma*alpha)/s*(1-tau*omega^sigma)/(omega^(sigma-1)*(1-gamma)*L*(1/tau-tau));
taro
Hello all,
When I try to do this example, in the multibody analysis, http://www.maplesoft.com/products/maplesim/ModelGallery/detail.aspx?id=137
Thats already written :
but when I enter theses formulas(mModel & MB), that write instead of the example:
"Analyzing system..."
"Performing constraint analysis..."
"The system has 2 degree(s) of freedom. It is modeled using 2
generalized coordinate(s) coupled by 0 algebraic constraint(s\
And I have no result if i do vPosCons := MB:-GetPosCons(); . What am I doing wrong?
First 1391 1392 1393 1394 1395 1396 1397 Last Page 1393 of 2429
