(A o C) o Colimit = (B o C) o Colimit
if known A, B, C and framework of Colimit
can it be said colimit?
Bonus, what are A,B,C? <- this can be not answered
I want (Maple) to do a series of time consuming computations while I sleep so I create a Vector V of length 50 say and make each computation an entry in V.
An occasional entry will turn out to be an error-that is, I get an error message and the calculations stop. Not a serious problem if the first 47 entries have been calculated but if the thrd calcuation fails I have little to show for a night's work.
What I want if for Maple to skip any computaion that fails (produce the appropriate  error message if possible) and then continue with the other computations.  Any suggestions?
Here is an unrelated question. If I have an Array T say
>T:=Array(3..5,7..17,(i,j)->i^2*j):
then T[4,10] returns the appropriate entry. T(2,4) returns the same thing. What type of object is T(-,-)?
So I have two simultaneous equations,
T= n1/(1+|T-S|) and S=n2/(n3+|T-S|)
Where n1, n2 and n3 are constant parameters (from here on I fix n1=1 and n3=0.3). So I want to plot T, S against n2 for different values of n2.
If I also fix n2 (say, n2=1.5) I  can get values for T and S no problem.
But I've no idea (after many hours of searching) how to progresss. I know I need the program to put various values of n2 into the two equations and then plot the solutions numerically but I'm unsure what to try next.
Could anyone please shed some light on this?!
I'm trying to numerically calculate the following:
int(e^(-1.5*t)/sqrt(t*(t+1)), t = 1 .. infinity)
But Maple can't do it.
I then made it a lot simpler and tried to calculate the following:
evalf(int ((e^(-t)), t=1..infinity));
Thats just e^(-t), integrated from t=1 to t=infinity.
Maple just gives me back the original equation in the first case, and in the second gives me a limit that I can see has a numerical answer, but Maple can't. Is this something Maple should be able to do and I'm just now pushing the right buttons? I'm using Maple 12, which I know is old and limited, but these really aren't very complicated numerical integrations.
solve matrix equation Ax+Bx=C,x is n*n matrix ,forA,B,C is n*n matrix . write maple procedure and check a 2*2 case.
I can not interpret this answer.
I think here I is the complex unit.
I tried to used some statistical methods to analyze the data in maple and encountered some problems.
I wanted to perform a cluster analysis to quantify differences among individual samples and hoped to create the dendrogram like this:
For example, each sample is assigned to a cluster and there are about 4 main clusters plus additional outliers in this case through the dendrogram method.
But I didn't find any related command to create this kind of graph. How to realize this analysis in Maple?
I'd appreciate any help on this topic. Thank a lot.
after integration,
result is x^2
f := x^2
we know in the range 5..-5 = 5^2 - (-5)^2 = 0
this example is not good enough, as i can be any number x, -x
if in another example, i use a and b to represent that would like to find
3*a^2 - 3*b^2 = 0, how to find possible a and b?
my example is not good, is there example that a and b are different number, not only in sign
i have a sense that substitution represent associative x*y and x+y
is my understanding correct?
if i change associative property to gcd and lcd,
how to do composition?
if associative is a pair of function, x+y, x*y
does it mean that non associative should also a pair
is it possible replace substitution with two operation x+y and x*y?
How to find inverse function of a multivariable function
for example
f := x^2 + y + z^3
f := x^2 + y^3
Gentlepeople.
Given 6 teams [A,B,C,D,E,F] I require that each team plays each other once.
 I can generate the pairs:
lst:=combinat:-choose({A,B,C,D,E,F}, 2);
{{A, B}, {A, C}, {A, D}, {A, E}, {A, F}, {B, C}, {B, D}, {B, E}, {B, F},  {C, D}, {C, E}, {C, F}, {D, E}, {D, F}, {E, F}}
On a competion night three pairs will compete and it will take 5 nights for all teams to play each other.
now I need some eredite richard who can show me how to produce the five night output:
(instead of comma a 'v' needs to be mapped)
AvF
BvD
CvF
I am trying to invert a function and, during the course, wind up with something like,
a_1*V^P*V + a_2*V^P*V^2 + a_3*V^P*V^3 + a_4*V^P*V^3 + a_5*V^P*V^3 + a_6*V^P*V^4 + \cdots
is there a way to get the poly into a form
(a_1+a_2+...)*V^P + (b_1+b_2+...)*V^(P+1) + (c_1+c_2+...)*V^(P+2) + .....
Thanks. Attached is my Maple 16 sheet.
with(LargeExpressions)
main := V^P*(V-1)^Q = c^(P-Q)*X^Q*(V-c^2)^Q
assume(Q, real); additionally(Q > 0); additionally(Q, integer)
assume(P, real); additionally(P > 0); additionally(P, integer)``
you := proc (s, n) V[1] := s; for i to n do V[i+1] := (`@`(simplify, expand))(c^((P-Q)/P)*X^(Q/P)*(-c^2+V[i])^(Q/P)/(V[i]-1)^(Q/P), symbolic) end do end proc
proc (s, n) local V, i; V[1] := s; for i to n do V[i+1] := (`@`(simplify, expand))(c^((P-Q)/P)*X^(Q/P)*(V[i]-c^2)^(Q/P)/(V[i]-1)^(Q/P), symbolic) end do end proc
START*HERE
START*HERE
Rearranging "main" leads to the following.
main2 := X^Q = V^P*(V-1)^Q/(c^(P-Q)*(V-c^2)^Q)
It can't take a series due to the series about zero, so I split it into
split := X^Q = V^P*(a[1]+a[2]*V+a[3]*V^2+O(V^3))
Then I'll get a polynomial expression, switch places of the two variables' leading terms, and substitute into the "original" polynomial (split).
  one := (V-1)^Q/(c^(P-Q)*(V-c^2)^Q)
two := `assuming`([simplify(`assuming`([series(one, V, 3)], [V > c^2, c > 1]))], [real])
series(c^(-Q-P)-(c^(-Q-P-2)*Q*(c^2-1))*V+((1/2)*c^(-Q-P-4)*Q*(-c^4+c^4*Q+1+Q-2*Q*c^2))*V^2+O(V^3),V,3)
three := convert(two, polynom)
c^(-Q-P)-c^(-Q-P-2)*Q*(c^2-1)*V+(1/2)*c^(-Q-P-4)*Q*(-c^4+c^4*Q+1+Q-2*Q*c^2)*V^2
four := simplify(expand(V^P*three))
V^P*c^(-Q-P)-V^(P+1)*c^(-Q-P)*Q+V^(P+1)*c^(-Q-P-2)*Q-(1/2)*V^(P+2)*c^(-Q-P)*Q+(1/2)*V^(P+2)*c^(-Q-P)*Q^2+(1/2)*V^(P+2)*c^(-Q-P-4)*Q+(1/2)*V^(P+2)*c^(-Q-P-4)*Q^2-V^(P+2)*c^(-Q-P-2)*Q^2
five := collect(four, V, factor)
collect(five, V)
factor(five, V)
Error, (in factor) 2nd argument, V, is not a valid algebraic extension
Download invert2.mw
Hi Maple Prime-ers!
I have a question about efficiency.  I have a set of algebraic equations with some polynomials, that I would like to solve at different points.  I've tried using a for-loop and a map-loop.  Here is a example:
n:=10000;  #Number of solving points
eq1:={b = ''a^2'', c = b^3/2, d = c^(1/2)*4 + b^2}; #Equation to solve
a := convert([seq(i,i=1..n)],Vector);  #timesteps
ans := Vector[column](n)
## Try solving in a for-next loop
t1 := time():
for q from 1 to n do
ans(q):=solve(subs({'a' = a(q)},eq1)):
t2 := time() - t1;
## try solving in a map loop
t1s := time():
ans_s := map(q->solve(subs({'a' = a(q)},eq1)),a);
t2s := time() - t1s;
On my computer (2.2Ghz, 2 cores), these both take 115s to solve.  Using Map over For-Next did not speed up computational speed.
The problem I wish to tackle has 12 equations, invovles 5th order polynomials, and n ~= 300000.  Solving this set of equations takes 2-3 hours.
Anyone know a more efficient method?  Thanks for reading :D
Please look at the following set.
restart; Z := {x1*(h1+h3) = 0, b1*x1+b4*x3 = 0, f2*x2+f3*x1 = 0, g2*x2+g4*x3 = 0, d1*x1+d2*x2+d4*x3 = 0}; for i to numelems(Z) do print(Z[i]) end do; "++++++++++++++++"; h3 := -h1; x3 := x2; g2 := -g4; Z; print("The following loop gives wrong result! The last element d1*x1+d2*x2+d4*x2=0 of set Z have disappeared!"); for i to numelems(Z) do print(Z[i]) end do
x1*(h1+h3) = 0
b1*x1+b4*x3 = 0
f2*x2+f3*x1 = 0
g2*x2+g4*x3 = 0
{0 = 0, b1*x1+b4*x2 = 0, f2*x2+f3*x1 = 0, d1*x1+d2*x2+d4*x2 = 0}
0 = 0
b1*x1+b4*x2 = 0
f2*x2+f3*x1 = 0
0 = 0
Why?
Download Set.mw
Notepad displays alt+1, alt+2 and alt+3 as ☺☻♥
Just wondering why Maple displays them as square boxes?  Shouldn't it have the font capability to display them as well?
First 1466 1467 1468 1469 1470 1471 1472 Last Page 1468 of 2429
