I encounter "insufficient  initial/boundary value" error message,  do know how to proceed from there, search with "insufficient initial value" gets no result. Any help will be appreciated.
> restart; alias(r = r(t), f = f(t)); with(plots);
r, f
> DE := diff(r, t) = 2*r+alpha*r*f, diff(f, t) = -f+alpha*r*f;
d d
--- r = 2 r + alpha r f, --- f = -f + alpha r f
dt dt
> NULL;
> params := alpha = .3;
alpha = 0.3
> initv := r(0) = 101, f(0) = 2;
> NULL;
> dvars := [r, t];
> chaodisplay := proc (chartname) EQ := [op(subs(params, [DE])), initv]; EQ1 := dsolve(EQ, numeric); odeplot(EQ1, dvars, t = 0 .. 300, axes = frame, numpoints = 50000, color = green, orientation = [-30, 100], title = chartname) end proc;
Warning, `EQ` is implicitly declared local to procedure `chaodisplay`
Warning, `EQ1` is implicitly declared local to procedure `chaodisplay`
> chaodisplay("Rabbit and Fox");
Error, (in dsolve/numeric/type_check) insufficient initial/boundary value information for procedure defined problem
Dear people being here,
I have a question.
When I wrote as
aa:=(delta[1]*n[1])/(n[f1]*delta[1]);
maple returned as
aa := n[1]/n[f1]
How can I have maple express the original one, aa:=(delta[1]*n[1])/(n[f1]*delta[1]), not what returned to me?
I hope you will answer to my question.
And, thanks in advance.
taro
Please help me, here my problem:
Parsing a string works correctely like this:
ABC := 3443;
print("ABC = ", eval(parse(cat("A", "B", "C"))));
But using PROCEDURE it doesn't work:
myParse := proc ()
     local PEA;
      PEA := 4334;
      print("PEA = ", eval(parse(cat("P", "E", "A"))))
myParse();
                        "PEA = ", PEA
I suppose to have "PEA = ", 4334
how to make a table of newton raphson ?
working is below
printf("No           root                   x[i+1]                 abs(x[i+1]-x[i])\n"); for i to n do y[i] := evalf(x[i]+(-D1(x[i])+sqrt(D1(x[i])^2-2*f(x[i])*D2(x[i])))/D2(x[i])); x[i+1] := evalf(y[i]-f(y[i])/sqrt(D1(x[i])^2-2*f(x[i])*D2(x[i]))); printf("%d         %10.10f     %10.10f       %10.10e \n", i+1, x[i+1], f(x[i+1]), abs(x[i+1]-x[i])); if abs(x[i+1]-x[i]) < tol then print("approximate solution" = x[i+1]); print("No of iterations" = i+1); break end if end do
please help me
Hi, I need to show some how by using Maple, that n^3>(n+1)^2 where n>=3. Iam new at Maple and not sure how I can graph inequality as n goes to infinity. Any help would be appriciated. Thanks!!!
I'm asked to solve the equations below simultaneously using fsolve.
f := x*exp((1 - x)*a);
f[2] := subs(x=f,f);
eq[1] := f[2] - x;
eq[2] := diff(f[2],x) + 1;
fsolve({eq[1],eq[2]},{x,a}):
fsolve doesn't seem to work here for some reason.
Any help help would be great!
Hi Everybody,
I'm having some problems simulating an algebraic system in Maple.  I want to do this for a larger system of equation (~20 equations/20 variables, with 3 inputs), but I'd like to get an idea of the form this should be in.
So, using an example out of Maple help:
with(DynamicSystems);
sys1:=AlgEquation([y=sin(x)],[x],[y],discrete=true,sampletime=0.001);
inp1:=Vector[column]([1,2,3,4,5,6,7]) * 0.1;
res:=Simulate(sys1,[inp1]);
Error, (in DynamicSystems:-Simulate) should never be here
I don't understand what this error means.  Reading the example in the help files, says the second argument should be a vector of input values.  What I would assume this would do is plugin x = 0.1, then solve y=sin(0.1), and output y.
Am I missing some syntax, or is my inputs wrong?  There are examples of how to set up an algebraic system in the help files, but no examples of how to simulate them.
Thanks in advance for any help!
Hello all. I have a probably simple problem, that is drinving me totally crazy. I have a expression having:
 (sqrt(M+m)*sqrt(M-m).(sqrt(M+m)*sqrt(M-m))
and it refuses to simplify. I told maple assume(m>0, M>0), etc. But it doesn't want to simplify. Anyone has any ideas?
Jelmew
Edit: uploaded the mw file, so it can be seen what the problem is.10.1.mw10.1.mw
[I added Physics to the tags.--Carl Love as moderator]
Hi, i'm trying to solve the simultaneous equations,
a[1]:=2*x^2 + 3*x^2 + x*y - x^2 + x;
a[2]:=3*y^2 + 4*x^2 - y;
eval(y,fsolve({a[1],a[2]},{x,y}));
0.
Even though y can be 0 it can also be 1/3 and two other complex numbers.
How do you get fsolve to show all four y solutions.
Secondly, how would i get maple to just to show the positive y solution ie. 1/3 only.
my question may be simple but I don't find the answer in any help guide.
when I define a function I cannot use a linearalgebra expression such as Trace.
Here is an example of what I would like to do:
If anyone can help me...
I need to plot the band structure of Graphene using Maple, Ive written out the eqn as given in the homework, but when i hit enter it says "error. unable to match delimiters"
i have no idea what that means, here is the eqn i have typed into Maple:
http://imageshack.us/photo/my-images/39/j7ri.jpg/
http://img39.imageshack.us/img39/733/j7ri.jpg
i have been given values for gamma and acc, do i just type them in after, E is a function of k (kx,ky,kz) do i put that in brackets after the E?
E(kx,ky,kz)
Error, (in Statistics:-NonlinearFit) invalid input: no implementation of NonlinearFit matches the arguments in call
after tried many times, got this error
x11 := [0.208408965651696e-3, -0.157194487523421e-2, -0.294739401402979e-2, 0.788206708183853e-2, 0.499394753201753e-2, 0.191468321959759e-3, 0.504980449104750e-2, 0.222150494088535e-2, 0.132091821964287e-2, 0.161118434883258e-2, -0.281236534046873e-2, -0.398055875132037e-2, -0.111753680372819e-1, 0.588868146012489e-2, -0.354191562612469e-2, 0.984082837373291e-3, -0.116041186868374e-1, 0.603027845850267e-3, -0.448778128168742e-2, -0.127561485214862e-1, -0.412027655195339e-2, 0.379387381798949e-2, -0.602550446997765e-2, -0.605986284736216e-2, -0.751396992404410e-2, 0.633613424008655e-2, -0.677581832613623e-2]:
y11 := [ -21321.9719565717, 231.709204951251, 1527.92905167191, -32.8508507060675, 54.9408176234139, -99.4222178124229, -675.771433486265, 42.0838668074923, -12559.3183308951, 5.21412214166344*10^5, 1110.50031772203, 3.67149699000155, -108.543878970269, -8.48861069398811, -521.810552387313, 26.4792411876883, -8.32240296737599, -1085.40982521906, -44.1390030597906, -203.891397612798, -56.3746416571417, -218.205643256096, -178.991498697065, -42.2468018350386, .328546922634921, -1883.18308996621, 111.747881085748]:
z11 := [ 1549.88755331800, -329.861725802688, 8.54200301129155, -283.381775745327, -54.5469129127573, 1875.94875597129, -16.2230517860850, 6084.82381954832, 1146.15489803104, -456.460512914647, 104.533252701641, 16.3998365630734, 11.5710907832054, -175.370276462696, 33.8045539958636, 2029.50029336951, 1387.92643570857, 9.54717543291120, -1999.09590358328, 29.7628085078953, 2.58210333216737*10^6, 57.7969622731082, -6.42551196941394, -8549.23677077892, -49.0081775323244, -72.5156360537114, 183.539911458475]:
a1 := Diff(x1(t),t) = k1*x1(t)+ k2*y1(t)+ k3*z1(t);
b1 := Diff(y1(t),t) = k4*x1(t)+ k5*y1(t)+ k6*z1(t);
c1 := Diff(z1(t),t) = k7*x1(t)+ k8*y1(t)+ k9*z1(t);
ICS:=x1(1)=x11[1],y1(1)=y11[1],z1(1)=z11[1];
sol:=dsolve({a1,b1,c1,ICS}, numeric, method=rkf45, parameters=[k1,k2,k3,k4,k5,k6,k7,k8,k9]);
ans:=proc(p1,p2,p3) sol(parameters=[x1=p1,y1=p2,z1=p3]); end proc:
tim := [seq(n, n=1..27)];
ExperimentalData := <<x11>|<y11>|<z11>>;
FitParams:=Statistics:-NonlinearFit(ans, ExperimentalData,initialvalues=[k1=0,k2=0,k3=0,k4=0,k5=0,k6=0,k7=0,k8=0,k9=0], output=parametervalues);
main_screened_Poisso.mw
In the attached Maple program I construct a matrix of which the entries involve numerical integration. Nothing difficult, I think, yet the ReducedRowEchelonForm is taking forever. What am I doing wrong?
expect to export a series of graphs, but no diagram,
then i debug to export one diagram, it is success, why in this case not export
https://drive.google.com/file/d/0B2D69u2pweEvcDZVZ0tsRTc2dTg/edit?usp=sharing
with(combinat):
list1 := permute([a, b, a, b, a, b], 3);
list1a := subs(b=1,subs(a=0, list1));
n := 3;
list1a := permute([seq(seq(k,k=0..1),k2=1..n)], n);
list2 := permute([a, b, c, d, e, f, g, h, a, b, c, d, e, f, g, h, a, b, c, d, e, f, g, h], 3);
list3 := subs(h=18,subs(g=17,subs(f=16,subs(e=15,subs(d=14,subs(c=13,subs(b=12,subs(a=11,list2))))))));
list3 := permute([seq(seq(k,k=11..18),k2=1..3)], 3);
Iter:= iterstructs(Permutation([seq(seq(k,k=11..(10+nops(list1a))),k2=1..3)]), size=3):
list3b := [];
while not Iter[finished] do
p:= Iter[nextvalue]();
list3b := [p, op(list3b)];
list5 := Matrix(nops(list1a)*nops(list3), 1);
count := 1;
for n from 1 to nops(list3) do
temp1 := subs(1=list1a[1],list3[n]);
for k from 11 to nops(list1a)+10 do
temp1 := subs(k=list1a[k-10],temp1);
od;
list5[count] := temp1;
count := count + 1;
od;
Lfh := proc(numoflevel, hx, fx, varx)
if numoflevel = 1 then
hello := 0;
for kk from 1 to nops(var) do
hello := hello + diff(hx[kk], varx[kk])*fx[kk];
od;
return hello;
hello := 0;
hello := hello + diff(Lfh(numoflevel-1, hx, fx, varx), varx[kk])*fx[kk];
od;
return hello;
CheckRelativeRankZero := proc(h1, f1, g1,variables1,Count)
IsFinish := 0;
Result := 0;
for ii from 1 to 8 do
if IsFinish = 0 then
Lf2h := Lfh(ii,h1,f1,variables1);
Print(“Lf2h=”);
Print(Lf2h);
Lgf2h := Lfh(1,[seq(Lf2h,n=1..nops(variables1))],g1,variables1);
if Lgf2h = 0 then
print(“Lgf2h = 0”)
print(f1);
print(Lf2h);
print("find at ", ii);
IsFinish := 1;
Result :=Lf2h;
od;
return Result;
IsZeroMatrix := proc(h1)
Iszero := 1;
for ii from 1 to 3 do
for jj from 1 to 3 do
if h1[ii][jj] <> 0 then
Iszero := 0;
end if
od;
od;
return Iszero;
with(combstruct):
list6:= convert(list5, list):
list7 := [];
for ii from 1 to nops(list6) do
if list6[ii] <> 0 then
list7 := [list6[ii], op(list7)];
od;
with(VectorCalculus):
varlist := [x1, x2, x3];
Iter:= iterstructs(Permutation(list7), size=2):
Count := 1;
with(DEtools):
Count := 1;
list8 := [];
I1 := 0;
I2 := 0;
if IsZeroMatrix(p[1]) = 0 and IsZeroMatrix(p[2]) = 0 then
group1 := Matrix(p[1]);
if group1[ii][jj] = 1 then
I1 := I1 + varlist[ii]*varlist[jj];
od;
od;
group2 := Matrix(p[2]);
if group2[ii][jj] = 1 then
I2 := I2 + varlist[ii]*varlist[jj];
od;
od;
f2:=[I1, I2];
g2:=[0,-1,1];
h2:=[x1,0,0];
Lf2h := CheckRelativeRankZero(h2,f2, g2, varlist, Count);
print(“Lf2h=”);
print(Lf2h);
RightSide := MatrixMatrixMultiply(Matrix([[0,diff(I2, varlist[3]),-diff(I2,varlist[2])],[-diff(I2, varlist[3]),0,diff(I2, varlist[1])],[diff(I2, varlist[2]),-diff(I2, varlist[1]),0]]), Matrix([[diff(I1, varlist[1])],[diff(I1, varlist[2])],[diff(I1, varlist[3])]]));
print(“RightSide”);
print(RightSide);
Lf2_h := Lfh(1, Lf2h, f2, varlist);
LgLf_h := Lfh(1,Lfh(1,h2,f2,varlist),g2, varlist);
if LgLf_h = 0 then
u:=0;
u := -Lf2_h/LgLf_h;
newsys := [Diff(x1(t),t) = subs(x3=x3(t),subs(x2=x2(t),subs(x1=x1(t),RightSide[1][1]))) + g[1]*u,
Diff(x2(t),t) = subs(x3=x3(t),subs(x2=x2(t),subs(x1=x1(t),RightSide[2][1]))) + g[2]*u,
Diff(x3(t),t) = subs(x3=x3(t),subs(x2=x2(t),subs(x1=x1(t),RightSide[3][1]))) + g[3]*u];
eval(plotsetup):
`plotsetup/devices`[jpeg]:=[jpeg,`plot.jpg`,[],[],``]:
plotsetup(jpeg, plotoutput=cat(cat(`testhamiplot`, Count),`.jpg`),plotoptions=`height=700,width=800`);
DEplot3d(value(newsys), [x1(t), x2(t), x3(t)], t = 0..1,[[x1(0) = 1, x2(0) = 1, x3(0) = 1]]);
Count := Count +1;
Hi, I am trying to write a procedure that inputs two matrices (A,B) and vector (C), it then multiplies C by A, and thenC by B and adds these to the array, it then multiplies each other them by A and B and adds them to the array etc up to (N-1)^2 (N will be given), this is what I hve so far, I am trying to write an if loop inside to say if it's already in the array then do not add it again but i'm unsure. Any help would be appreciated thanks!
proc_cerny1:=proc(A::Matrix,B::Matrix,C::Vector,N)
local x, S, i, j, T, R, y;
x:=(N-1)^2;
S:=Array([]);
S[0]:=C;
i:=0;
j:=0;
while (i<(2^N)) do
T=S[i].A;
S[j]=T;
j=j+1;
R=S[i].B;
S[j]=R;
i=i+1;
for y from 0 to j do
if (S[y]=T) then
S[i]=S[i]-T;
fi:
print(S);
First 1492 1493 1494 1495 1496 1497 1498 Last Page 1494 of 2429
