Good morning Sir,
The output of Gompertz Model is showing exponential decay values but it is stated that
it is on of the exponential growth models. Please clarify this ambigity. The following problem is one such example
Fit a Gompertz growth model to the following data
Hi, again:
Is there a way to connect Maple with Sqlite?
C.L.
Hi:
I would like to ask maple to "recognize" a Fourier transform in a (possibly complicated) expression.
Maple defines a Fourier transform in this way:
convert(fourier(f(x), x, k), Int);
So if f(x)=1 we should get something that is proportional to Dirac(k), which we do:
fourier(1, x, k);
...but given an expression
exp1:=Int(exp(-I*x*k), x = -infinity .. infinity);
... how would tell...
Error:
File: error-series.mw
Please help?
Now it's division by zero, help...
File: division by zero
Bonjour,
Je cherche une méthode éfficace pour résoudre le système d'équations polynomiales suivant :
with(SolveTools):
> PolynomialSystem({f0,f1,f2,f3,f4,f5,f6},{alpha,lambda,mu,nu});
# avec les fi ci-dessous :
f0:= (1+mu+nu+lambda)*alpha^3*(1+mu+nu)*(mu^2-2*mu*alpha+2*nu*alpha*mu+2*mu-2*nu*alpha+2*nu*alpha^2+alpha^2-2*alpha+1+alpha^2*nu^2)*(-lambda*alpha^3+3*mu*nu+alpha^2*lambda-lambda+3*nu*mu^2+3*nu*mu^2*lambda+l...
I tried this on maple:
eps1 := [0, 1/5, 2/5, 3/5, 4/5, 1]:
start1 := 2.3:
base1 := 1.1:
for i from 1 to 6 do
R := start1*base1**0:
points1[i] := [R, evalf(eval(mH, {M=1, r=R, epsilon = eps1[i]}))]:
for a from 1 to 20 do
R := start1*base1**a:
points1[i] := points1[i], [R, evalf(eval(mH, {M=1, r=R, epsilon = eps1[i]}))]:...
Good afternoon sir,
I am getting the reslut around a=22 degreees  instead of 33 degrees when solved the following Trigonometric equation
A sin α cos α + B sin2 α − C cos α − E sin α = 0,
where A = lsin β1, B = l cos β1, C = (h + 0.5D) sin β1 − 0.5Dtan β1,
and E = (h + 0.5D) cos β1 − 0.5D.
Good morning sir,
Please help me out to fit the Gompertz growth model using Maple.
with thanks & regards
M.Anand
I am trying to finish up an assignment but this problem is giving me issues. The problem is to find the first positive value of x=2sinx to within 10^-5
I used the following code
with(Student[NumericalAnalysis]);
f := x-2*sinx;
                           x - 2 sinx
a := 1;
Hi. I have two problems connected to Physics package and complex numbers. The main problem is undesired decomposition of a complex value t into Re(t)+I*Im(t).
The first problem is connected...
Hello....
how to convert decimal to binary??
for example [10, 3,90,6]..
how to convert this number into binary??
I have a list contains the triagles with in each triangle has mesure of the angle AOB equal to 45 degrees. Now I want to select four points in list so that they lie on the graph of the funtion y = (ax + b)/(cx + d), where c <> 0. This is the code which I make the list.
> restart:
ListTools[Categorize]:
N:=10:
L:=[]:
for x1 from -5 to N do
I want to use Maple (dsolve command) to solve this problem, how do I input the command? Part (a) is enought.
I have tried the command, but Maple says "Warning, for {u(t)} arbitrary the system is inconsistent".
Thank you very much for your help.
First 1530 1531 1532 1533 1534 1535 1536 Last Page 1532 of 2430
