When the Fourier transform to the heat equation for example it is useful to represent the Fourier transform of a derivative as the derivative of the transform.  Thus
        FT{d(U(x, t)/dt}  = d(FT{U(t))} / dt,
Where FT => Fourier transform wrt the variable x.
How do I get Maple to obtain the above.
Joe Salacuse
l*`ℏ`*t*sqrt(4*`ℏ`^2*a^2*t^2 + m^2)/(sqrt(2*I*`ℏ`*t*a + m)*sqrt(-2*I*`ℏ`*t*a + m)*m) can be simplified :l *h*t/m
How can I ask Maple to do this.
Given
expr:=  (x^(-(44 + 12*sqrt(69))^(1/3)/6 + 10/(3*(44 + 12*sqrt(69))^(1/3)) + 2/3)) - (x^(sqrt(69)*2^(1/3)*((11 + 3*sqrt(69))^2)^(1/3)/100 - (11*(44 + 12*sqrt(69))^(2/3))/600 - (44 + 12*sqrt(69))^(1/3)/6 + 2/3))
could someone come with a trick to show this is zero using simplification and other methods? I know I can use is and coulditbe but I do not trust these too much due to false positives I've seen from them in some places.
Here is my attempts
expr:=  (x^(-(44 + 12*sqrt(69))^(1/3)/6 + 10/(3*(44 + 12*sqrt(69))^(1/3)) + 2/3)) - (x^(sqrt(69)*2^(1/3)*((11 + 3*sqrt(69))^2)^(1/3)/100 - (11*(44 + 12*sqrt(69))^(2/3))/600 - (44 + 12*sqrt(69))^(1/3)/6 + 2/3));
simplify(expr);
simplify(expr,size);
simplify(expr,symbolic);
simplify(normal(expr));
simplify(normal(expr),symbolic);
simplify(expr) assuming real;
simplify(expr) assuming positive;
is(expr=0);
coulditbe(expr=0);
evalb(expr=0);
Gives
This is for reference, the Mathematica attempt
long time ago I asked about automatic spacing to improve latex for sqrt. A nice solution was provided in https://www.mapleprimes.com/questions/231062-Adding-Space-After-Sqrt-To-Improve-The-Latex
The above is activatived using spaceaftersqrt = true option for latex:-Settings
There is a similar issue for inert integration where a space is typically added before the final dx This is done similar to the above fix using \, See for example this Latex web site giving many examples.
But there is no option I could see to tell Maple to do this automatically for integration.
So all my inert integrals now look not too good as the dx is too close to the integrand. Here are 2 examples with the settings I am using
latex:-Settings(useimaginaryunit=i,
      usecolor = false,
      powersoftrigonometricfunctions= mixed, ## computernotation,
      leavespaceafterfunctionname = true,
      cacheresults = false,
      spaceaftersqrt = true,
      usetypesettingcurrentsettings=true,
      linelength=10000
sol:=sqrt(4*y^3-a*y-b)*a;
Intat( subs(y=a,1/sol),a=y(x));
latex(%);
Int(sol,y);
latex(%);
I copied the latex and compiled it, and this is the result
\documentclass[12pt]{book}
\usepackage{amsmath}
\begin{document}
\int_{}^{y \left(x \right)}\frac{1}{\sqrt{4 a^{3}-a^{2}-b}\, a}d a
\int \sqrt{4 y^{3}-a y -b}\, a d y
\end{document}
Which gives
Compare the output when adding \, by hand to the latex
\begin{document}
\int_{}^{y \left(x \right)}\frac{1}{\sqrt{4 a^{3}-a^{2}-b}\, a}\, d a
\int \sqrt{4 y^{3}-a y -b}\, a \, d y
\end{document}
Which now gives much better result
Actually, what would be nice if the "d" in "dx" was mathrm which becomes
\begin{document}
\int_{}^{y \left(x \right)}\frac{1}{\sqrt{4 a^{3}-a^{2}-b}\, a}\, \mathrm{d} a
\int \sqrt{4 y^{3}-a y -b}\, a \, \mathrm{d} y
\end{document}
But may be I am asking for too much here. But having an option to add \, only for inert integration will be good to have.
Does there exist an option to do this that may be I overlooked?
Maple 2023.2
I have the function: 2*sin(x)+1/2x-1
I want the x-intercepts, but Maple only provides one answer with fsolve.
plot(2*sin(x)+1/2*x-1)
I am trying to find the integer numbers a, b, c, d, t so that the equation sqrt(a x^2 + b x + c) = d x + t have two integer solutions. My code
First I solve
solve(a*x^2 + b*x + c = (d*x + t)^2, x);
I get
(2*d*t - b + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2))/(2*(-d^2 + a)), -(-2*d*t + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2) + b)/(2*(-d^2 + a))
And then, I solve
n := 0;
for a to 10 do
for b to 10 do
for c to 10 do
for d to 10 do
for t to 10 do
mydelta := 4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2;
if 0 < mydelta and type(mydelta, integer) then
x1 := (2*d*t - b + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2))/(2*(-d^2 + a));
x2 := -(-2*d*t + sqrt(4*a*t^2 - 4*b*d*t + 4*c*d^2 - 4*a*c + b^2) + b)/(2*(-d^2 + a));
if 0 < d*x1 + t and 0 < d*x2 + t and type(x1, integer) and type(x2, integer) and nops({a, b, c, d, t}) = 5 and c <> t^2 and -d^2 + a <> 0 and nops({x1, x2}) = 2 then n := n + 1; L[n] := [a, b, c, d, t]; end if; end if; end do; end do; end do; end do;
L := convert(L, list);
nops(L);
I don't get any solutions. But, when I  solve(sqrt(2*x^2 + 3*x + 5) = x + 9, x); I get two solutions 19, -4.
Where is wrong in my code?
S := [1, 2];
                          S := [1, 2]
T := [1, 2];
                          T := [1, 2]
is(S = T);
Sv := Vector([1, 2]);
Tv := Vector([1, 2]);
is(Sv = Tv);
is(convert(Sv, list) = convert(Tv, list));
how to solve tis type of pdefirst_order_pde.mw
I obtained a Plot p, then trying to find if it has Float(undefined) in it. I am basically trying to find if DEplot returns an empty plot or not. I found that it the plot structure has HFlat(undefined) then this seems to imply an empty plot. So I said, then in the code I can check for HFlat(undefined) in the plot and it is there, then I know the plot is empty.
But this check is not working.
I used has(....,Float(undefined)) and this returns false. But if I copy and paste part of the plot structure and try the check on the copy, it gives true.
I do not understand what is the difference. First here is screen shot, and below if complete code to reproduce.
ode2:=2*y(t)+t*diff(y(t),t) = t^2-t+1;
p:=DEtools:-DEplot(ode2,y(t),t=0..3.5,y=0..3,
                        linecolor = red,
                        arrowsize ='magnitude',
                        numpoints = 200 ,
                        axes = boxed,color = ('magnitude[legacy]')):
p0:=Array(1 .. 3,1 .. 2,{(1, 1) = HFloat(undefined), (1, 2) = HFloat(undefined), (2
, 1) = HFloat(undefined), (2, 2) = HFloat(undefined), (3, 1) = HFloat(undefined
), (3, 2) = HFloat(undefined)},datatype = float[8],order = C_order);
whattype(p0);
has(p0,HFloat(undefined))
p1:=op([1,2],p);
whattype(p1);
has(p1,HFloat(undefined))
Worksheet attached also.
Maple 2023.2 on windows 10
                        linecolor = red,
                        numpoints = 200 ,
2*y(t)+t*(diff(y(t), t)) = t^2-t+1
whattype(p0);
Matrix(3, 2, {(1, 1) = HFloat(HFloat(undefined)), (1, 2) = HFloat(HFloat(undefined)), (2, 1) = HFloat(HFloat(undefined)), (2, 2) = HFloat(HFloat(undefined)), (3, 1) = HFloat(HFloat(undefined)), (3, 2) = HFloat(HFloat(undefined))})
hfarray
p1:=op([1,2],p);
whattype(p1);
hfarray
question is: Why the above give different result? And what is the correct way to check if the output plot from DEplot is empty or not (in code)?
Download why_has_works_different.mw
The documentation says:
A for...in loop can optionally have two loop variables. … If the second variable is the name _ (a single underscore), this indicates that the value is not needed, and Maple may choose to not look it up, and not assign a value to _.
So “_” can be treated as an argument placeholder in a for–in loop. Nevertheless, I would like to know if there is an argument placeholder like MatLab's tilde (~) operator:
Ordinarily, there is no need to to ignore inputs in function definitions, but as for the former, since there is a _nresults keyword in Maple (and some "built-in" routines do use it), when accessing the source code is unavailable, how do I ignore specific outputs from such a function (e.g., a procedure with option encrypted that has been loaded from a repository)?
For instance, the help page of MTM:-eig mentions three calling forms:
  1. l := MTM:-eig(A):
  2. [V,L] := MTM:-eig(A):
  3. [V,L,N] := MTM:-eig(A):
If I do not directly invoke the linalg/Student[LinearAlgebra]/LinearAlgebra/Matlab package (and do not manually compute Eigenvals), will it be possible to imitate MatLab's
[~, ~, W] = eig(A);
in Maple as verbatim as possible?
Note that MatLab's help page claims:
… In this case, the variables are small. However, some functions return results that use much more memory. If you do not need those variables, they waste space on your system. …
Hello, I'm trying to automate a series of priority calculation exercises. I have a problem with the "/" and " " division symbols. The "Parse" command only accepts "/" .Thanks for your insights
PEMDASTest.mw
Assume
a:=2 m
b:=3 m
I will then calculate A as a times b, but Maple just gives med the answer 6 m2.
I would like the output to become:
A = a * b = 2 m * 3 m = 6 m2   (with * as normal multiplication-dots)
It is possible to write at proc with the above output? It should work for any expression.
The argument of the function should just be the name of the expression. Fx:
showCalculateProc(A)
The showCalculateProc(A) should then give the output
I know about InertForm[NoSimpl], but it doesn't do all I want it to do, and not so nice output (* as multipliction)
With the context-panel
P(x, y) = exp(-(x^2+y^2)/(2*sigma^2))/(2*Pi*sigma^2)
P(x, y) = (1/2)*exp(-(1/2)*(x^2+y^2)/sigma^2)/(Pi*sigma^2)
subs(sigma = 523.*Unit('`&mu;m`'), P(x, y) = (1/2)*exp(-(1/2)*(x^2+y^2)/sigma^2)/(Pi*sigma^2))
P(x, y) = 0.5818576570e-6*exp(-0.1827959741e-5*(x^2+y^2)/Units:-Unit(`&mu;m`)^2)/Units:-Unit(`&mu;m`)^2
How to format all occurences of numbers?
Download Number_Format.mw
Dear Maple   help me to  to plot the graph please see and rectify.  thanks in advance
i am attaching the codes
inf:=5:
pdes:= R(X,R,t)*diff(U(X,R,t),X)+U(X,R,t)*diff(R(X,R,t),X)+R(X,R,t)*diff(V(X,R,t),R)+V(X,R,t),
         diff(U(X,R,t),t)+U(X,R,t)*diff(U(X,R,t),X)+V(X,R,t)*diff(U(X,R,t),R)=Gr*T(X,R,t)+Gc*C(X,R,t)+(1/R(X,R,t))*diff(R*diff(U(X,R,t),R),R),
         diff(T(X,R,t),t)+U(X,R,t)*diff(T(X,R,t),X)+V(X,R,t)*diff(T(X,R,t),R)+(1/(Pr*R(X,R,t)))*diff(R*diff(T(X,R,t),R),R),diff(C(X,R,t),t)+U* diff(C(X,R,t),X)+V(X,R,t)*diff(C(X,R,t),R)+(1/(Sc*R(X,R,t)))*diff(R*diff(C(X,R,t),R),R):
conds:= U(X,R,0)=0, V(X,R,0)=0, T(X,R,0)=0,  C(X,R,0)=0,
        U(X,1,t)=1, V(X,1,t)=0, T(X,1,t)=1,  C(X,1,t)=1,        U(0,R,t)=0, T(0,R,t)=0, C(0,R,t)=0,
        U(X,int,t)=0,T(X,int,t)=0,C(X,int,t)=0:
pars:= { Gr=5, Gc=10,Sc=2.0}
              pars := {Gc = 10, Gr = 5, Sc = 2.0}
PrVals:=[0.71, 1.00, 1.25, 2.00]:
  colors:=[red, green, blue, black]:
  for j from 1 to numelems(PrVals) do
      pars1:=`union`( pars, {Pr=PrVals[j]}):
      pdSol:= pdsolve( eval([pdes], pars1),
                       eval([conds], pars1),
                       numeric
      plt[j]:=pdSol:-plot( U(X,R,t),X=1, t=2, R=0..inf, numpoints=200, color=colors[j]);
  plots:-display( [seq(plt[j], j=1..numelems(PrVals))]);
I have expressions with head Sum that are all either one single Sum or sum of these Sum's. So my expression is either
Sum(.....)+Sum(....)+Sum(...)   or Sum()
Inside each Sum, I have indexed a[n] and also possibly nonindexed For an example
             Sum( a[n]*x + a, n=1..10)
And I want to change all the indexed a[n] to b[n]
Hence the example above it will becomes  Sum( b[n]*x + a, n=1..10)
I can't just use eval(expr,a=b) as that will also change the non-indexed a to b which I want to leave as is. There will be only one single indexed variable in the sum. In this example it is `a`
Below is a general example and my solution. I'd like to find if there is a more canonical way or shorter more direct way to do this in Maple.
expr:=Sum(x^(n+r)*a[n]*(n+r)*(n+r-1)+a[n-1]+3*a*x^10,n = 0 .. infinity)+Sum(4*a*x^(n+r)*a[n],n = 0 .. infinity)+Sum(4*a[n-1]*x^(n+r)+a[n]*x+a*x,n = 1 .. infinity) = 0;
evalindets(expr,specfunc( anything, 'Sum' ),f->Sum(evalindets(op(1,f),'indexed',ff->b[op(ff)]),op(2,f)))
I used evalindets twice. Once to look for Sum, and then to look for 'indexed' within each sum. It seems to work. Here is screen shot of the output
If you asking why I have indexed a and non indexed a in the same expression? Well, it is because the non-indexed happend to be a coefficient of the ode that the user used. So it is part of the input, which I have no control over. But the indexed is a local variable I am using inside the function being called to process the input.
On the screen they look the same. But they are actually not the same. The indexed is local to the function and the non-indexed is input via argument. So it is global symbol.
First 157 158 159 160 161 162 163 Last Page 159 of 2429
