I have this small code as example:
> restart:with(LinearAlgebra):
> e1:=5*x1-x2+6*x3+10*x4-10;
                 e1 := 5 x1 - x2 + 6 x3 + 10 x4 - 10
> e2:=x1-x2+x3-10*x4;
                      e2 := x1 - x2 + x3 - 10 x4
> e3:=2*x1+3*x2-8*x3-x4+20;
I need to know how I can obtain a curve with different color. I work with Maple 15
I have a function like this:
Plot (C1, C2, C3, t=1..200, color= red, green, dark)
where C1, C2, C3 are mathematic function and t is the time because these function depend of time.
I need to know where the curve is obtained how can I know that the color green correspond to the second function?
Thanks you in advances.
Hi, I am creating a garden with plan view   in Maple. Garden with plan view
I want to create a train in my garden, so i need to create 1/4 annulus. How do I make that?
The instructions say:
"To create the X package you have to execute 'maple -s -q X.mpl'
on the command line and then you will get two files X.lib and X.ind."
For some reason I was not able to create the files on the command line (Windows).
Threfore I tried read "C:/.../X.mpl". Now I got the error:
"Error, on line 38, syntax error, cannot open $include file: series.mpl: $include "series.mpl"
Is it the `$´ character to which Maple points to (^...
 I am conveting ordinary differntial equations into polynomial using differential tranformed method and also after using pade arroximants for finding converge point at infinity. because differential transform cannot satisfy boundary at infinity. EQ1 and EQ2 does not built up fromt he preceeding iterations. its pade approximants diagonal value results like pade[3,3],[4,4],[5,5] and so on. i can solve this type for single equations but when  i solve coupled equations...
How can I create a rectangle in Maple knowing 4 points?
> with(geometry);
> point(A, 0, 0); point(B, 0, -15);
B
> line(facade, [A, B]);
facade
> point(C, -3, 0); point(d, -3, -15);
d
> line(facadepar, [C, d]);
I have a very simple (possibly stupid) question.
I am wondering if there is a simple way to model a mass on a rope (or string) in MapleSim, and measure the tension in the rope. Any suggestions would be helpful.
Karis
I have a HOMEUSE licence including Maple 15, MapleSim 5, with Driveline and Tyre Libraries. Does anyone know when the intergated Maple 16 / MapleSim 6 will be release for upgrade?
Hello all,
I'm trying to solve nine non-linear equations for various input. I am using a for loop to vary the input, and for few input combinations there is no solution. I am trying to exclude these and print the values only if there is a solution. After looking at some of the forms I used if (not type(sol[7], numeric) then print("no solution") else print(sol[7]) end if but this is the output I am getting for all the input.
Attached is the maple...
restart; with(plots); with(LinearAlgebra); with(linalg)
I am trying to import data from one maple sheet to another but don't know how can I do that.  Its basically plots which I have to compare.  There is answer to question but as I am begginer I couldn't understand the sharing of engine theory.
Any simple example will be of great help.
Many Thanks
A.Q
I am trying to analyse a nonlinear ode. To see the behaviour,
I am using implicit plot (suggested by @Preben Alsholm).
The problem is that every time I need to search for the value of N
(=infinity) to have some sort of graph (needed for analysis).
The other thing is, if we have an output of the implicitplot, How we can be sure
that it is the correct one?
I have been messing around with MapleSim for a while now, and I cannot find a good way to model something such as a spiderweb. I want to be able to model a spiderweb (using something like cables), and then measure the tension in the cables, and also vibrations as they travel through the cables. Is this something that I can accomplish using MapleSim? If so, what is the best way to approach this problem? Any suggestions or comments would be helpful. Thanks.
Can anyone help me with this error in Maple while using prcNewton to find local extrema:
> prcNewton := proc ()
local ftn, strpt, epsilon, maxlps, i, xn, dftn;
if 4 < nargs then
elif nargs < 2 then end if;
if nargs = 2 then
epsilon := 1/10000000;
maxlps := 1000
elif nargs = 3 then
First 1677 1678 1679 1680 1681 1682 1683 Last Page 1679 of 2430
