Hey everybody,
I'm tring to display text plots with lines and points. When I use the display command and change the size of the display, the font size does not change with it. Is there any way to have the plotted text to change size with the display?
-Patrick
how to solve this partial differential equation  :
d/dx[(1+e*T)dT/dx]+P*dT/dx-B*T=0
e ,p ,b are constants and t is temperature.
plz help in finding a solution for this differential...or the closest method to simplifying it...
I am trying to overload the "." operator (noncommutative product) to handle objects I have implemented as records. Each record contains a matrix R and a parameter l. A.B will produce a new record where l is l_A+l_B and R is R_A.R_B, "." here being the normal matrix product (and I use LinearAlgebra:-Multiply in the body of my procedure for this). The objects A and B are of type 'Element', which I have defined (using AddType) and which works.
I implemented the procedure...
@Markiyan Hirnyk
Sorry about that I was not aware of this problem.  I have written now in text as follows:
In the following there needs to be two if conditions applied i.e. one for the k / p = 1,3,5,7   and second
if (m*Pi = k*bo)    and also same for if (m*p is not equal to k*bo)
When I try to solve it says invalid if statement termination:
oddratioeval-_maplep.mw
I need your kind suggestion to solve the equation for odd ratio.  I am attaching Maple file for the purpose.   I have to evaluate a function for odd ratio and for other values its zero.  I need help in assigning this odd and even ration to the function.  k can vary from 1...15, depending on ratio.
I shall be very thankful for your kind responses.
what is the window use for maple 16: vista, xp, or win 7?
Question 1. After googled, x*diff(F,t)+t*diff(F,x) for two variables, how about three variables or general ?
Question 2.
if deal with on variables case using the example in
http://demonstrations.wolfram.com/AFunctionInvariantUnderAGroupOfTransformations/
F := (x^2-x+1)^3/((x^2)*(x-1)^2)-y;
G:=y*diff(F,x)=0;
sol:=solve(G,y);
F(H)-F = 0
sol:=solve(F,x);
H := simplify(subs(y=F, sol[1]));
all above code can...
maplehelprequired.mw
I am trying to solve the equation for values k=1 to 10,  but the issue is when I put k=1 equation goes to infinity.  I am attaching Maple file for your kind consideration.  I have also included an example which may help you to answer.  I couldn't understood how its done.
Best Regards
A.Q
@Markiyan Hirnyk
Dear Markiyan,
Since you took the time to think about this problem and help me, I think I should ask my problem in full instead of just part of it. I believe, then, you will perhaps agree that the issue at hand is not a prejudice against a procedure. By all means, I am interested in solving the problem with ANY method. In my...
Hello! I am running the same piece of maple code on different machines, and I have noticed that the powerset function returns the sets in a different order. For example,
Maple 11 (X86 64 LINUX)
> powerset(3);
            {{}, {1, 2, 3}, {2, 3}, {3}, {1, 3}, {1}, {2}, {1, 2}}
Maple 14
> powerset(3);
            {{}, {1}, {2},...
Hello Maple experts,
 I want to find out k-th probability (denoted by c(k)) which is expressed as an integration of summation for values ranging from j=0 to k. The function is very complicated , I have attached the PDF for expressing the mathematical term properly.
I am able to find out the c(k) for a given value of k, if k is specified in the beginning of the maple program. But I am unable to make it generic form of k.
I have also attached the...
mapleprimesifconditi.mw
I am stuck in defining two conditions for the equation.  I am attaching Maple file for your kind consideration.
Actually I want to assign the value of k=1, and when k is not =1, for G11(k).
I shall be very thankful for your kind replies.
Best Regards
A.Q
Hello, Maple wizards.
Can we talk about how to perform arithmetic efficiently on submatrices? To illustrate, let matrices A and B be represented by a block structure using submatrices, so that A and B are
A11  A12
A21  A22
B11 B12
B21 B22
respectively. I want to efficiently replace the lower submatrix A21 A22  with A21+B21   A22+B22.
Here's the catch (to me, anyway): the indices representing...
hi
consider the following ode
eq1:=diff(f(x),x$3)+f(x)*diff(f(x),x$2)+diff(f(x),x$1)^2;
subject to thease boundary condition
f(a)=0,D(f)(b)=0,D(D(f))(0)=0
where
b= infinity (in computational domain b=10 is acceptable )
the exact solution of ode is
f(x)=tanh(x/2)
but when i want to solve it with Dsolve, maple get the zero. how can i use this ode in maple
First 1707 1708 1709 1710 1711 1712 1713 Last Page 1709 of 2430
