hi,
please Help me in the following code :
> restart;
i:=0;
u[i](s):=A+B*s-C*exp(-s);
lambda(s,x):= -(1/2)*(s-x)^2;
tre(s,x):=lambda(s,x)*(diff(u[i...
I have a set of nonlinear and coupled PDEs for a cable actuated system. I want to transfer this set to a set of ODEs and write it down in Matrix form. I used Galerkin's method and derived the ODEs in discritized form. I have a problem in converting this set of equation into a matrix form like "Mq"+Cq'+Kq=F". The derived equations are very complicated and contains some nonlinear terms. One of the three equations looks like this:
i want to create my own package Helloworld (includes proc1 and proc2) so that people can do
with(Helloworld);
and get
[proc1,proc2]
and then they can then use proc1 and proc2 as they wish.
thanks in advance
When the numerator of a quotient is a negative integer, Maple puts the quotient into parentheses and the negative sign before the quotient (not with the numerator). Here is an example:
with(RandomTools);
a1 := Generate(integer(range = -10 .. -1));
Limit(a1/(x-3), x = 3, right);
I would like to have the negative sign with the numerator and to remove the parentheses.
I tried to export the limit in MathML, but it didn't work.
In...
hi,
i want to solve this equation :
f(n+1)(x)=f(n)(x)-int [ (s-x)^2 * ( F"(n)(s)+.5*F(n)(s) ) ds]
 integration is from  -infinity  to  x
with this initial guess   f(0)(x)=A+Bx+C*exp[-x]
i want for example F(4)(x) in terms of A,B,C
 and then calculate A,B and C with this condition
f(0)(4)=0
f'(0)(4)=0
f'(10)(4)=1
please help me
thancks
Dear guys
I have an expression and I solve it by "solve". It has two results and I want to choose first of them. How can I choose for example the first result? Is the order of results the same if I run the program many times?
For the following system:
x1 := M*(cos(phi)-a*cos(3*phi)) / (1-b*cos(2*phi))
x2 := M*(cos(phi)+a*cos(3*phi)) / (1+b*cos(2*phi))
y1 := M*(sin(phi)-a*sin(3*phi)) / (1-b*cos(2*phi))
y2 := M*(sin(phi)+a*sin(3*phi))/ (1+b*cos(2*phi))
I'd like to find M(x1,x2,y1,y2) if possible; that is, I'd like to solve for M in terms of x1, x2, y1, and y2, eliminating a, b, and phi.
I've tried
solve({x1=X1, x2=X2, y1=Y1, y2=Y2},{M,a,b,phi},AllSolutions);
Hello all,
 Is any anyone know how good is maple numeric stiff ode solver (stiff=true) ? What i mean is how many stiff ode's it can handle at a given time. I am having a hardtime solving a system of ode's (say 300 stiff ode's). Is there any other numeric stiff ode solver in maple that can handle large number of ode's?
I used islode advanced numeric solver for stiff ode's and it also has some limitations on the number of ode's and moreover it is slow.
I have been investigating Predator-Prey spatial models, e.g.
diff(N(x, t), t) = r*N(x, t)*(1-N(x, t)/K(x, t))-a*N(x, t)*P(x, t)+d[1]*(diff(N(x, t), x, x))
diff(P(x, t), t) = P(x, t)*(b*N(x, t)-c)+d[2]*(diff(P(x, t), x, x))
How to Plotting Matrix  8 × 8 matrix:
0, 0, 0, 0, 0, 0, 0, 0
0, 1, 1, 1, 1, 1, 1, 0
0, 1, 0, 0, 0, 0, 1, 0
0, 1, 0, 1, 1, 0, 1, 0
This matrix would correspond to the following image where 0=black and 1=white.
Gracias
independent.mw
initial/boundary conditions can only contain derivatives which are normal to the boundary
I got this message when trying to solve a system of three PDEs numerically. Does anyone knows what it mean? Thanks.
newlam
How to output a list when writing a procedure
i want to get the list c in the procedure, but "return" c not work
z := [x1, x2, x3];
symMonomial(z)
symMonomial := proc(test)
with(combinat):
h := 0;
for i from 1 to nops(test) do
    h[i] := choose(z,i);
od;
c := 0;
for k from 1 to nops(test) do
    c[k] := 0;
    for i from 1 to nops(h[k]) do
        ki := 1;
I start with a question, but not an how-to question, because I am puzzled by why such a routine is missing.
Why does Maple not have  generalized Schur (real and complex) factorizations with reordering?  The nice solution of many dynamic equations requires this factorization because the lhs is singular. MatLab does have such a routine. At the moment, it seems, one has to have accessible and connect to MatLab or NAG or LAPACK for such routines.
Is this...
Is there a way to select multiple entries in a ListBox component?
Using the following script with cmaple I got a plot with three legend elements. (see img link).
How can I remove Curve 3 and Curve 5 entries?
plotsetup(gif,plotoutput=`test_maple.gif`,plotoptions=`color,noborder,portrait`):
l:=10^(-3);
Vel:=(y,t)->sum(n*y*t, n = 0 .. 10);
Vel1 := plot(...
First 1839 1840 1841 1842 1843 1844 1845 Last Page 1841 of 2430
