Just a simple question:
How do I unassume (remove the assume) all the variables in my code in the easiest way?
Thanks a lot for your help.
In a loop (variables set to some calculation) when maple produces an error how can I set it to a value of zero?
I want to find the first positive and first negative root of a bessel function
j2 := (x, a) -> k(x)^2*a^2*(diff((diff(1000000000*sin(1/1000000000*k(x)*a)/(k(x)*a), x))/(k(x)*a), x))/(k(x)*a)
I couldn't use the built in bessel function with two variables, so I had to enter it by hand.
I want to find the values of x where j2 is zero as a function of a:
f := (a) -> RootOf(j2(x, a), x, 0 .. 2)
plot(f(a), a = 2 .. 2.25, y = -3 .. 3)
Hey folks. I have a massively complicated equation I'm trying to solve and the internal memory can't take it.
Here is the problem.
Let f(x) := 1 - lambda*x^2
alpha := 1/f(1)
By solving the following equation,
alpha*f(f(x/alpha)) = f(x) + O(x^4)
We can determine a value of lambda and hence alpha (for which the real value is roughly -2.5 and the calculated value here is roughly -2.7).
hello everybody
please heeeelp
In the name of God
Dear friends
I have a question about releasing a part of memory occupied by some lists, sequences and matrices, for example matrix "M" or list "L".
If we use the following commands to allocate amount of memory for a matrix or list:
M:=Matrix(2000,2000,float[8]);
L:=[seq(equ[i],i=1..10000)]:
where equ[i...
hello everybody can you help me please
how can i canvert this list [1,2,3,4,5,6] to a number 123456
hi ,friends
  now ,i get a matrix of symbolic expression,it's difficulty to find the simplest forms using the common command  as like simplify or combine
p := Matrix(4, 4, {(1, 1) = (1/2)*exp((1/2)*J[1]-(1/2)*J[2]+(1/2)*J[3])+(1/2)*exp(-(1/2)*J[1]+(1/2)*J[2]+(1/2)*J[3]), (1, 2) = 0, (1, 3) = 0, (1, 4) = (1/2)*exp((1/2)*J[1]-(1/2)*J[2]+(1/2)*J[3])-(1/2)*exp(-(1/2)*J[1]+(1/2)*J[2]+(1/2)*J[3]), (2, 1) = 0, (2, 2) = (1/2)*exp(-(1/2)*J[1...
Hello friends,
When I solve the optimization problem with restriction (below):
NLPSolve( ln(x1) +ln(x2+5), {x1 +x2 <=4}, assume = nonnegative);
     [-Float(infinity),
       [x1 = HFloat(0.0), x2 = HFloat(0.8333333333333334)]]
I get the expression  "-Float(infinity)"..
What do Float(infinity) and  HFloat(0.833333) mean?
Thanks for the attention,
Hello everybody!
I'm working on a statistical problem. I need to plot confidence regions for parameters in the model, but I don't know what I should do. I tried to get some programs from the internet, but either they don't work or I don't understand details of them to change for my work. Can someone introduce a good program to me?, or does anyone have another useful idea for me?
Thanks a lot!
I meet a problem in the use physcis package.
    for example,
                                   restart;  with(Physics); Setup(mathematicalnotation = true):
I am analyzing a system that was at steady state and then subjected to a step change.  I have the steady state modeled with a system of ODEs.
I am going to model the step change with a system of PDE's.  The system will be discretized in space and time (z,t).  I know how to setup one side of the boundary conditions (0,t) for all variables, but the other (i.e A(z,0)) I would like to use the results of the steady analysis. Does anybody have some ideas on...
I would like to do the following
A[1,1],A[2,2],A[3,3]:=seq(i+2,i=1..3)
using seq on the left-hand-side. I know I have done it in the past but don't get it this time. End up with error messages. Not sure what am I missing.
thanks a lot
Dimitrios
I typed  x:=a*cos(t)^3
For a while it was handling this correctly.
But then it started replacing the multiplication sign by ~ every time it used this or anything similar.
Something has changed the status of the a .
If I use b instead of a, it works fine.
Hello Maple experts,
I call "out" the development of the sum(x^2, x=a..b):
"out":= sum(x^2, x=a..b);
     1        3   1        2   1     1   1  3   1  2   1
out=     - (b + 1)  - - (b + 1)  + - b + - - - a  + - a  - - a
First 1932 1933 1934 1935 1936 1937 1938 Last Page 1934 of 2431
