I am recently new to maple software, but I was wondering if someone was able to help me with the following question.
I am trying to plot a 3D graph of some function f(x,y,z), I want a contour type-graph with normal axis, and I also have a few points that I want to plot on that graph:  [x1,y1,z1], ... [xn,yn,zn]; how do I do this on a single graph?
thanks so much;
How to change this general form to solve :
How to calculate with Maple Fourier coefficients on some numerical valued functions and how to calculate and plot the 3 partial sums :
Function B : on the interval [-phi, phi]
f(x)= NUMERICAL (x – phi/2) + NUMERICAL (x+phi/2)
Function C : on the interval [-phi, phi]
f(x) =  NUMERICAL (x+phi/2)
I enclose Maple general solution to the PDF heat equation in 1 dimention.
I need corrections of it to enable me to calculate the heat equation in certain conditions :
 du(x,t)/dt - d^2/x,t)/dx^2 = ;   t>0, x belongs to interval [0,phi[
with boundary conditions :
u(x,0) = sin(x)cos^2(x) ; x belongs to interval [0, phi)
u(0,t) = 0
u(phi,t) = 0  ;  t is still t>0
I have 3 different arrays. is there any way that I can put these 3 arrays in one table with a proper heading above each column?
I am trying to create a pointplot animation for a list can anyone tell me what is wrong with the following code:
with(Statistics):
L:=[[1],[3, 2],[3.4, 6], [5,3,7], [3,7,9,1], [2,6,8,4,5]]:
animate(PointPlot, [L[t]], t=1..5);
I am trying to animate a graph to show the progress between each suset from t = 1 to n.  I belive the problem has something to do with t not being an integer in the animate setting.
I get this strange (to me) behavior:
interface(showassumed=0);
assume(theta,real);
assume(phi,real);
SourcePosition:=[phi,theta];
parameters:= [SourcePosition[1],SourcePosition[2]]:
 save parameters, "./parameter.txt";
wanted_par:=[convert(SourcePosition[1],string),convert(SourcePosition[2],string)]:
save wanted_par, "./wanted_par.txt";
I Wanted To Model a Ball Screw in MapleSim4, I should  Imply a force to the base of the ball screw while the nut is attached to a fix pint and I expect the shaft of the ball screw rotates. I would be so thankful If any one tell me an idea how to model it to use at Maplesim4 for as I could not find any component for ball screw on MapleSim.
Looking forward to hearing from you
I wanted to plot Laplace's spherical harmonics, which basicly worked. But now I wanted to add two sliders with which i want to vary m and l. This also works nearly. I can vary l and plot the new spherical harmonic. The variable m has to hold the restriction: -l<= m < = l.
So my question is, how can i synchronise the two sliders, so that when i edit silder l the range for slider m is changed?
Thanks for your help!
> restart;
> with(linalg);
> uvec := array(1 .. 2, [u_(x, y, t), v_(x, y, t)]):
> xvec := array(1 .. 2, [x, y]):
> equns := array(1 .. 3, []):
> for i to 2 do
   equns[i] := sum('uvec[j]*(diff(uvec[i], xvec[j]))', 'j' = 1 .. 2)
the result the maple 11 gives is:
I have created a Monte Carlo simulation using maple using the following do loop for each iteration:
for count from 1 to n do
end do
I would like to show through animation (pointplot) how the model develops with changing n.
Can anyone help me with this problem?
Thanks in Advance
I have created a Monte Carlo simulation using the following do loop for each iteration:
end do
I would like to show through animation how the model develops with changing n.
Thanks in Advance
I'm solving a non-linear system of equations (8 equations, 7 parameters) numerically using Fsolve.
Here's my problem: I run fsolve in a loop for different values of one specific parameter. What I would like to do however is have a matrix of parameter values and tell fsolve to pick a new row of that matrix each time as parameter values until it has run down all the rows.
I just need some general guidelines and the commands. Much appreciate the help...
I was wondering if there is a more elegant way of doing this:
SX := proc ()::set; local j, sx, SEqn; Digits := 30; SEqn := {evalf(subs(EV, Eqn(1)))}; for j from 2 to n do SEqn := `union`(SEqn, {evalf(subs(EV, Eqn(j)))}) end do; sx := SEqn end proc:
Charles
Please , can anybody tell me about the basical things to know about Maple that are not described in the internet . I mean about adding a new line with the sign > , joining or parting two parts , or insert a title and above all where i can find the list of the pakages wee need to perform a program .
hi
I have this PDE:
PDE := diff(f(x, y), x, x)+diff(f(x, y), y, y) = 0
With BCs
bc := {f(0, y) = 0, f(1, y) = 0, f(x, 0) = 0, f(x, 1) = sin(Pi*x)}
which has a relatively simple exact solution.
I'm trying pdsolve and getting nowhere, either numerically or symbolically.
Any advice most welcome
PL
First 1990 1991 1992 1993 1994 1995 1996 Last Page 1992 of 2431
