I have an equation for inviscid bubble expanding of the form:
ode:=R(t)*diff(R(t),t,t)+(diff(R(t),t))^2-1/R(t)=0
Sol:=dsolve(ode, numeric, initialConditions:=R(0)=R0,D(R)(0)=0)
Now, I want to plot the following expression:
Sol2:=1/R(t)
How can I do it?
Thanks ahead,
Mark
See the post link below which gives the ability to find the gradient of a vector, not a scalar field.
http://www.mapleprimes.com/forum/gradientvectornotgradientscalarfunction
The solution was to use the Jacobian command.  Now I need to take the time derivative of that expression because now the velocity is a function in time.  Unfortunately, MAPLE wants an algebraic expression for d/dt operations.  What command to I need to use for this operation??
poi:=x->exp(-0.2225)*0.2225^x/x!;
for i from 0 to 4 do > evalf(poi(i)*10000,2) > od;
  1. Is there a way to write procedures in Maple which return procedures?
    1. If there is, would you please give me an exemple?
  2. What's the difference between writing a procedure with '->' and 'proc'?
Hello!!!
I have an equation written in several terms: Q:= T1+T2+...+T37.
I want Maple to present my equation Q in the order I typed but it sorts it in an strange way, for example, the order would be: Q:=T5+T3+T35+...+T3.
Because terms T1...T37 are quite complicated expressions, I need Maple to keep them in the order I indicated in the sum.
Is there anyway that I can force Maple to keep it in the right order?
my programme seems to be giving me all permutations on a nXn board been trying to find where i went wrong but its took me days and still cant locate ... i want this procedure to give me the n queens on a nxn board that are non attacking. please help
.place:=proc(z)
global L;
local i,k;
k:=z;
L:= Array(1..k);
for i from 1 to k do
if L(i)=L(k) # two in the same column
or abs(L(i)-L(k)) = abs(i-k) # in the same diagonal
then
return (false);
fi:
return (true);
I am trying to view some fairly involved 3D plots in Maple 10, where I both construct some polyhedra, and label the points. When I click on the image, in order to rotate it, etc., it vanishes. Generally, I can recover it if I slightly scroll the page up or down (manually -- Maple 10 has no scrolling from the mouse -ack!). But if I touch the image again, it vanishes again. This does not seem to happen if I view simpler images, but I need to view the sets, and their labels (vertices). Any ideas? Thanks!
(1/2)*sqrt(2)
I know that it is too simple, but if my expression has lots of these terms then it will take me some time to simplify it by hand.
I am looking for an automatic way to do it in Maple.
tlist := [ [s] ]:
  for j to 4 do
    if tlist[-1,1]=s then
      tlist := [ tlist[], [t,tlist[-1][]] ]
   tlist := [ tlist[], [s,tlist[-1][]] ]
  end if
tlist;
which gives result
[[s], [t, s], [s, t, s], [t, s, t, s], [s, t, s, t, s]]
is there an easier way of writing this?
Hi I am trying to plot sin (pi x) but maple says
I cant understand this warning, as when i put 3.14 instead of pi it plots a nice graph.
Please help
In Maple 13, I use: convert(arccosh(x),ln); Maple gives: ln(x+sqrt(x-1)*sqrt(x+1)); which is fine. Now try and convert back: convert(ln(x+sqrt(x-1)*sqrt(x+1)),arctrigh); Maple gives: ln(x+sqrt(x-1)*sqrt(x+1)); Why doesn't Maple return arccosh(x)? Thanks.
Hey
I was trying to use the command readdata to read a *.txt file in which I saved the results of some calculations that I obtained with a program that I wrote in C language.
I'm organizing the data in columns on the *.txt file. For example:
hello, how do I simplify an equation in cos and sin (or any other) into either of only cos or only sin. for example, imagine we have y=sinx + cosx. How do we ask maple to change the whole equation into terms of only sin or only cos?
tank you
rect := t -> Heaviside(t + 1/2) - Heaviside(t - 1/2)
intConv := (f1,f2) -> t -> (int(f1(t-tau)*f1(tau), tau = -infinity..infinity));
What I now wanna do is something like
plot(intConv(Heaviside, rect(-t)));
but it doesn't work and only
plot(intConv(Heaviside, rect));
works without giving arguments at all, even
plot(intConv(Heaviside(t), rect(t)));
doesn't work?
How can i input two equations in maple and intruct maple to find the points of intersection? giving me the coordinates of each point
First 2027 2028 2029 2030 2031 2032 2033 Last Page 2029 of 2431
