The following is a sample code that I tried in maple 10 standard.
My problem is that whenever a plot contains a function with negative values, a usual plot displays it as it should, but when i try to display it on a log scale, all i get is an empty plot
sample code:
f:x=-5;
plot(f(x), x = -10 .. 10, y = -10 .. 10, axis = [mode = log]);
this gives out an empty plot, with axis in range of 10^0 to 10^(-6) on both axes - maple seems to ignore the instruction to display negative values.
perhaps it would also be helpful if someone could point out how to turn these values into decimals.
Hi I have the following maple file. Is anyone able to convert the maple code of the calculation of the reflected lines to the simple mathematical steps which are used to calcualte it. The calcualtion of the outgoing ray is from: if (abs(dr) > 0.001) then # if slope = 0 no outgoing ray > m := (dr^2 - 1)/(2 * dr): > ix := (height - y)/m: # > if ix <> tx := -width: > ty := y + m * (tx - x): > elif # Calculation of outgoing ray > ix > width then #
Hi I have a small problem which i hoped you could help me with. On my personal computer i have installed Maple 10, so i could do some schoolwork home. But on the computers at my school we use Maple 8. When i try to open a file made in Maple 10 in Maple 8, i only get weird signs. So I have to copy everything i wrote at home, on to the school computer. Its not the end of the world, but it takes time. Is there any way to fix this? Is Maple 9.5 backward compatabil with Maple 8? Thanks in advance!
Hi there, Its the rookie again. Does anyone know how to apply a function, say tanh to every element of a matrix? I have looked at rtable_scanblock and maps but not too sure? I think I might need to write a procedure but again, I am not too sure. Regards, Steve
hello i am a final year maths student very inexperienced with maple. i am trying to obtain results with maple to show an algorithm in practice. the algorithm is a variation of an SOR algorithm used to solve an optimization problem. i realised that because the next term in the sequence (x^i+1) generated by my algorithm depends upon itself as well as x^i, i would have to try to compute each component of the vector x individually because the first entry in x^i+1 is only dependent on x^i, then the second entry in x^i+1 is dependent on x^i and only the first entry of x^i+1, which should have just been computed, etc.
I got the eigenvalues of the Jacobian matrix of a nonlinear time variant system. One of them is like: 0.5000000000e-2-0.2500000000e-2*y+0.5000000000e-2*x+0.2500000000e-2*sqrt(36.-12.*y-24.*x+y^2-4.*x*y+4.*x^2) Now I'd like to make x and y still vary with time, i.e. 0.5000000000e-2-0.2500000000e-2*y(t)+0.5000000000e-2*x(t)+0.2500000000e-2*sqrt(36.-12.*y-24.*x(t)+y(t)^2-4.*x(t)*y(t)+4.*x(t)^2) x(t) and y(t) bear a relation by differential equations. Any ideas on how I implement this? Thanks a lot!
Hi I have been trying to extract the data from an eigenvectors() command to an Excel file. I have tried some basic writedata() commands but without luck. I´m guessing that the "strange" format of the output from the eigenvectors() command: [eigenvalue1, algebraicmultiplicator, [eigenvector1]], [eigenvalue2, algebraicmultiplicator, [eigenvector2]], and so forth is what is causing the problem. Does anyone know how I can do this?? Would mean alot to me if anyone does since it is eigenvalues and eigenvectors from an 31x31 matrix....ehhm :) Best regards Einar
I wonder if someone could help me with the following situation. I copied the procedure 'differentiate' shown on p62 of the MAPLE10 Aadvanced Programming Manual. When I fed this proc w/ the parameters 2 - x + x^2 + 3*x^9,x as indicated on pg. 63 I did not get the result shown in the book. View 2292_P62 AdvancedProgrammingGuide.mw on MapleNet or Download 2292_P62 AdvancedProgrammingGuide.mw
Hi I am not quite sure why the variable,(Tw) is not plotted. It is dependent on all the variables evaluated in the ode calculations but yet the wall temperature, Tw, is not evaluated. Anyone could tell me why? Thanks a lot Elinor View 3860_extent of reaction (COKE).mw on MapleNet or Download 3860_extent of reaction (COKE).mw
View file
Hi everyone, Could you please have a look at my maple file. Im trying to solve a set of 4 differential equations but maple takes ages to solve and doesnot give the answer at the end either. The reason can be that the equations have to high power. Do you know any other dsolve method I can use or anything I can do to fix this problem? Thank you very much! Jinny View 3868_Pressure drop 2.mw on MapleNet or Download
Hi, I created a scatter plot in a Maple 11 Worksheet by creating a list (below) and right clicking and using the Plot tools. However, I want to graph a function on the same scatter plot. Can this be done? L := [[32, 6], [48, 14], [64, 24], [80, 38], [96, 55], [112, 75]]
Is there a package available in Maple that converts between number systems ? e.g., binary, octal, hexadecimal. v/r,
Thanks to all the wonderful and timely help I received concerning my previous troubles with the LegendreP function. It was all helpful. I think I'm very bad at procedures, but I struggled in an effort to gain more personal knowledge, in addition to solving this problem and came up with a very simple and rudimentary procedure. It is called P[legend](l,m), where l and m are the two arguments received in that order. Can anyone look at this procedure and suggest improvements for efficiency, aesthetics (more elegant simpler methods), possible bugs, etc. Your critiques on my effort would be greatly appreciated.
Somewhere along the line, my output format switched to display the most significant digit in the tenths decimal place. I can't figure out how to change it back to the unit (one's) decimal place. Anybody know where to find this setting? Thanks, Brad
First 2348 2349 2350 2351 2352 2353 2354 Last Page 2350 of 2429
