hi! Could somebody tell me if Maple has the capability of solving Partial Differential Equations using the method of Separation of Variables. Thanks, Raj
Hi: The following statements (output from a previous Maple calculation) results in a computer "freeze" when run under the latest version of Maple10 (Classic Worksheet) on a Windows XP machine. Definition: "freeze" - cursor halts midscreen and the machine refuses to respond to any keyboard commands, including ALT-CTRL-DEL 1. Can anyone reproduce this? WARNING - do not run this program if you have other windows open with data you want to retain. 2. Can anyone suggest how I can get the terms (1/x)^(-n1) and x^(-n1) to cancel? I've tried "simplify", "collect" and "combine" without success.
Dear Sir/Madam:
I try to find a close form for A^k,
where k is an arbitrary interger and A is 2 by 2 matrix as the following:
A = ([[r1*X, (1-r1)*X],[1-r2,r2]]);
r1 and r2 are symbolic constants, X is a variable.
First, I run the following commands in maple:
A:=matrix([[r1*X, (1-r1)*X],[1-r2,r2]]);
Z3:=A^3;
simplify(evalm(Z3),symbolic);
I hope to simplyfy the entries of Z3 in the order of X, i.e.,
z11 = a0*X^3 + a1*X^2 + a2*X +a3;
z12 = ....... (the same as the above)
z21 = .......
z22 = .......
But I do not know how to do it.
I try to find a law for representations of the entries of A^k by looking at the cases k=3,4,....
I am calculating the standard deviation of an function with StandardDeviation command both symbolically and numerically and I get different result for the symbolic and numeric calculation. The result of the symbolic calculation is wrong. Here is my problem: restart;with(Statistics): X := RandomVariable(Uniform(-Pi, Pi)); f:=1/abs(1-0.5*exp(-I*X)); StandardDeviation(f); # It gives 0, which is wrong. StandardDeviation(f, numeric); Re(%); Any idea?
I have a mechanics question with position given by phi = omega t theta = (1/2)Pi * (1+ (1/4)cos(4*omega*t)) r = b This is to be solved in spherical coords. That's not the problem. I solved this just fine, but I would really like to plot this to see what it looks like! Checking the help pages in maple, it says plot3d expects a function r(theta,phi) (might be the other way around?). So, is there a way to plot my 3 parts, or, failing that, how do I turn that into r wrt phi and theta? Cheers Chris PS. How do you post 2D math? I tried, but nothing really worked?
How can one print the output from the statements executed within a loop as the loop outputs only the last calculation.
I was wondering if anyone could tell me how to plot the direction field of a differential equation. I'm trying to plot ty'+2y=sint. If anyone could give me some advice, that'd be great.
I'm using the cosine function and just read in the help section that the trig functions only take arguments in radians. Is this true ? Is there no way to use arguments in degrees for the trig functions ? v/r, Dan
Hi, If a sentence (as a string) is given with uneven number of spaces in it, how can we smooth it out so that every word is followed by exactly one space. I think this would be solved by Regular Expression in patmatch, but exactly I don't know. Kindly help me. Thanks.
i have two function f(x) and g(x) and i wanna plot them in one plot x=1200..2300, but for f(x) y=0..600 and for g(x) y=0..50. How can i display different scaling y-axis?
Hi, I would like some help with plotting a 2D and 3D graph together. I actually have an equation with two varying parameters and I have displayed a 3D plot.What i want is to set a value for the one parameter and plot the line together with the previous surface, so that I can see where this line is placed on the surface.I provide the example to make myself clearer. Itouch50 := -0.4058074876e13*sqrt(1.+h)/(sqrt(ts)*(-500000000.0*ln((625.+125.*h+25.*h^2+5.*h^3)/h)* sqrt(1.+h)+587311661.7)) Itouch := 474335.0379*h*(10300.*2.718281828^(-3.703703704*ts)+1030.*2.718281828^(-3.703703704*ts)* h+490.*2.718281828^(1/(5.*ts+6.))+49.*2.718281828^(1/(5.*ts+6.))*h)/(51200.*sqrt(ln(100.*h))*h+5120.*sqrt(ln(100.*h))*h^2+25600.+12790.*h+511.*h^2)
Hello, I have never used Maple before and I am working on an assignment but unfortunately class ended before I could ask my professor with some help so I was hoping someone on here might be able to help me out. All I need to do is get the first equation to look like the second equation, I would use the simplify command but I cannot break apart the l(l+1), can anyone help me out?
Equation 1:
Need it to look like this:
View 3346_phy309as1.mw on MapleNet or Download 3346_phy309as1.mw
View file details
I want to tell maple that func is a function of x, y, z, but I don't know what the function is. This is so when maple evaluates derivatives, etc, it won't assume 'func' is a constant. ie: instead of func := (x,y,z) -> x^2 + 2y + 3xyz; I just want to say func : = (x,y,z); so that when I ask for a derivative, maple just prints out 'diff(func, x, 1) etc, where 'diff(func, x, 1) means the first partial deriv of x. I hope that's clear enough for all you experts out there. I am a newbie to Maple. I tried func : = (x,y,z); but it did not seem to work for me.... Thanks in advance,
Hello. I was wondering if it is possible to unassign a variable from within a procedure. The accompanying file illustrates what I am trying to do. As always, my anticipated thanks to anyone kind enough to take the time to help me. I would be totally lost in MAPLE without this forum. a href='http://maplenet.maplesoft.com/maplenet/worksheet/mapleprimes/2292_Unassign within a procedure.mw'>View 2292_Unassign within a procedure.mw on MapleNet or Download 2292_Unassign within a procedure.mw
Hi, Is there an easy way to convert Matlab or C code to something that Maple can use? I know CodeGeneration in Maple can go the other way, but can't import into Maple. Thanks! Andy
First 2358 2359 2360 2361 2362 2363 2364 Last Page 2360 of 2429
