Question: Mapping using multiple vectors
I'm looking for a quick way, preferrably without using any loops to 'map' a function using several vectors.
In the single vector case, this is quite easy, but with multiple vectors, I'm not sure if map is the correct command to use.
For example:
u:=<1,1,1>;
v:=<2,3,4>;
f:=(x,y)->ln(x-y);
What I'd like to do is create a new vector from the map of the function onto both vectors, using the u vector as the x values and the v vector as the y values without using a for loop.
Thanks in advance.
