Question: Optimization package in the Classic worksheet.
I was solving one Math puzzle and found out a strange behaviour of the Optimization package commands in the Classic Worksheet.
Let us minimize the function 7*x+3*y under the constraint 6*x+2*y >= 49 for non-negative integers. When I type
Optimization:-Minimize(7*x+3*y, {6*x+2*y >= 49}, assume = nonnegint);
in the Standard Worksheet (Maple 15), it works good and I get
which is correct. The help page ?Optimization/General/Options says that "The integer, nonnegint and binary values of the assume option are only accepted by the Optimization[LPSolve] command." So OK, I can also type:
Optimization:-LPSolve(7*x+3*y, {6*x+2*y >= 49}, assume = nonnegint);
and get the same result.
However, when I try to do it in the Classic Worksheet it doesn't work. When I try
Optimization:-Minimize(7*x+3*y, {6*x+2*y >= 49},assume=nonnegative);
then it is still OK. But when I type:
Optimization:-LPSolve(7*x+3*y, {6*x+2*y >= 49},assume=nonnegint);
I get Error, (in Optimization:-LPSolve) no feasible point found for LP subproblem
What more, when I type:
Optimization:-LPSolve(7*x+3*y, {6*x+2*y >= 49, x=8}, assume = nonnegint);
(I added x=8 constraint), the Classic Worksheet prints the message that "mserver stopped working" and I have to close the worksheet (I can not do anything else).
Does anyone know where the problem is?
