Question: Bug using evalf
An example:
evalf(frac(10^2*exp(1)));
0.8281828
Two digits lost.
And here is even worse:
evalf(frac(10^9*exp(1)));
0.
Correct unswer:
evalf[20](frac(10^9*exp(1)));
0.4590452354
The correct answer can be obtained only significantly increased  Digits. And if it were an intermediate result in a complex calculation? I could just do not know about this bug!
What is the cause of the error and is there  a general method to avoid it?
Thank you.
