Question: shaded area in plot and 95% confidence intervals
I am trying to get a shaded area in my plot but I could not.
First we solve ODE without randomness:
ode := diff(U(t), t) = -(A+B*U(t))*U(t);
Then we add randomness to ODE and solve:
ode2 := diff(U(t), t) = -(A+r(t)+B*U(t))*U(t);
A with randomness for r in R=( - 0.0001/365, 0.0001/365) is:
A(t,r)= A+r
Where A is constant =  0.0001/365
We plot both solution. For the plot I suppose to have a plot with shaded area that indicate the range of the 95% confidence intervals between highest and lowest simulation result at each time interval. I do not see a shaded are in my plote.
In:
R := RandomTools:-Generate(distribution(Normal(-0.2e-1, 0.4e-1)),100,confidence=0.95, makeproc = true);
is confidence=0.95 give me  95% confidence intervals between highest and lowest simulation result ?
is 100 will do 100 run?
Maple code:
> restart;
> with(DEtools); with(plots);
> k := 0; A := 0.37e-1; B := 0.2e-6;
> ode1 := diff(U(t), t) = -(A+B*U(t))*U(t);
> ic[1] := U(365*k) = 1000;
> sol[1] := dsolve({ode1, ic[1]}, U(t), range = 365*k .. 365*k+365, numeric);
> p[1] := odeplot(sol[1], [[t, U(t)]], t = 365*k .. 365*k+365, colour = blue);
> r := proc (t) if not type(t, numeric) then return 'procname(args)' end if; R() end proc;
> sol[2] := dsolve({ode2, ic[1]}, numeric, known = r(t), method = classical[foreuler], stepsize = 0.1e-1);
> p[2] := odeplot(sol[2], [[t, U(t)]], t = 365*k .. 365*k+365, colour = red);
> display(p[1], p[2]);
Thank you.
Thank you to Preben Alsholm for the help with randomness part.
