Question: plots, image size, eps
Hi
I have created a figure in Maple 15 using Plots:-display() command.  I want to save the combined figure (given by display) as a .eps format. I can do this by right-click on the image>export>Encapsulated Postcript. I need to run the code several times so that it produces a different image each time(by changing variables). I have to then click on the image and drag it so that it becomes the appropriate size I wanned.
My problem is that it is difficult to make each image the same size if i drag the image.
Is there a way that Maple can produce a plot to a given size and save it as a .eps format?
