Question: Maximum of a function of three variables
Dear Maple experts,
I have a function f  depending on three variables a,b,c i.e.   f(a,b,c).
I have to find the df/da (differentiation  with respect to a) and then solve for variable a in terms of variables b and c to make the f(a,b,c) into f(b,c).
However, I am not able to find the symbolic relation from df/da to represent variable a interms of variables b and c because the solve(df/da, a) is giving the solution interms of RootOf (_Z................some expression...... ... ).
Even after using assume command I am not able to avoid the RootOf ( _Z .............).
If this task can not be found in symbolically, can you advise a numerical command/method.
Looking forward to your reply
Thanks in advance.
