Question: why beta distribution is just a straight line
as i do not know what is nu and omega in beta distribution, can i solve it by equating with mean of real data's mean and stardard derivation, to find nu and omega, but solution of nu is negative,
i guess this method may be wrong, as result diagram is not fitted with real data
and weibull using this method, can not be solved and said solution lost
what is the correct way to draw it?
moreover, i add t = 5..15, it said not a range error, how to focus or magnify the range of two lines which some part overlapped
with(ExcelTools):
with(ListTools):
with(DynamicSystems):
with(Statistics):
filename := "1171.HK";
open3 := Import(cat(cat("C://Coal//",filename),".xls"), filename, "B2:B100");
high3 := Import(cat(cat("C://Coal//",filename),".xls"), filename, "C2:C100");
low3 := Import(cat(cat("C://Coal//",filename),".xls"), filename, "D2:D100");
close3 := Import(cat(cat("C://Coal//",filename),".xls"), filename, "E2:E100");
with(Statistics):
n := 0;
A := Array([close3[n+20][1],close3[n+19][1],close3[n+18][1],close3[n+17][1],close3[n+16][1],
close3[n+15][1],close3[n+14][1],close3[n+13][1],close3[n+12][1],close3[n+11][1],close3[n+10][1],close3[n+9][1],
close3[n+8][1],close3[n+7][1],close3[n+6][1],close3[n+5][1],close3[n+4][1],close3[n+3][1],close3[n+2][1],close3[n+1][1]]):
Y := RandomVariable(EmpiricalDistribution(A));
X := RandomVariable(NormalDistribution(Mean(A),StandardDeviation(A)));
plot([proc (t) options operator, arrow; CDF(Y, t) end proc, proc (t) options operator, arrow; CDF(X, t) end proc], x=5..15, color = [red, blue], thickness = 2);
X := RandomVariable(Beta(nu, omega)):
sol := solve( {Mean(X)=Mean(A),Variance(X)=sqrt(StandardDeviation(A))}, [nu, omega]);
X := RandomVariable(BetaDistribution(abs(rhs(sol[1][1])),rhs(sol[1][2])));
plot([proc (t) options operator, arrow; CDF(Y, t) end proc, proc (t) options operator, arrow; CDF(X, t) end proc], color = [red, blue], thickness = 2);
