Question: Problem in assigning variables in the rem and quo by their forth argument
The problem is as follows:
1- define r := rem(x^3+x+1, x^2+x+1, x, 'q')
2- then once you evaluate this expression, in variables list you may see r as the only variable, whereas q is the quotient variable and it is not provided there.
3- for example if you evaluate q it will give x-1
4- or even you can get the assigned varibles list by anames(user) and it gives both r an q
5- the question is: why q is not shown in variables list
I would become pleased if someone sheds some lights.
