Question: A problem with Setup(algebrarules = [...])
Hi
I am trying to define commutation rules between operators a1, a2, b1, b2.
with(Physics);
with(Library);
Setup(mathematicalnotation = true);
Setup(op = {a1, a2, b1, b2});
alias(A = %AntiCommutator);
algebra := [A(a1, a1) = 0, A(a2, a2) = 0, A(a1, a2) = 0, A(b2, a1) = 0, A(a1, b1) = 1,
A(a2, b2) = 1];
Se
tup(algebrarules = algebra);
However, the command Setup(algebrarules = algebra); causes an error. What is wrong? Noteworthy that if commutator is considered instead of anticommutator alias(A = %Commutator); then correct result follows.
Thank you.
