Question: Memory allocation question
I am running a Maple procedure in CLI Maple (mainly because it just provides colored random numbers for other work). When the procedure runs I am getting this kind of output scrolling by:
memory used=10732.9MB, alloc=344.0MB, time=895.85
memory used=10809.2MB, alloc=345.6MB, time=904.26
memory used=10885.5MB, alloc=347.3MB, time=912.67
memory used=10961.8MB, alloc=348.9MB, time=921.27
So I am wondering what "memory used" and "memory allocated" mean here. In "Activity Monitor" (this is Mac OS X) I see that the "memory allocated" values correspond rather closely to the "real memory" usage. No idea what the "memory used" column is. Note that this is a 32 bit process running on a PPS Mac, and it merrily "uses" unlimited amounts of memory that don't exist on the machine and that a 32 bit process should not be able to use (I think Mac OS X limits 32 bit processes to 4 GB). It is clearly not paging as the machine stays perfectly useable.
So, what am I to make of these numbers?
Mac Dude.
