Question: Solving ODEs with parametric ICs
Hi !
I wish to solve a differential equation with an initial condition of the type D(f)(a)=b, where 'a' and 'b' are arbitrary real constants and are entered this way symbolically. Maple interprets D(f)(a) as a function which depends on a new variable 'a' and gives the error:
Error, (in dsolve) found differentiated functions with same name but depending on different arguments in the given DE system: {f(a), f(psi)}
(the differential equation is for a function f(psi) which was defined previously)
How can I pass this initial condition f'(a)=b (a,b being constants, but arbitrary) to the Maple dsolve command?
I have been browsing the web and looking at manuals, but always find D(f)(0)=3 or any other combination with numbers only.
Thank you in advance.
Regards,
              Michael
