Question: Problem with involution
Hi everyone,
Consider this maple 18 doc: Euler18.mw
The code is regular code for Julia sets of the exponential.
To see how the Julia set behaves at infinity, I apply the transform mu(z)=1/z.
The plot3d command correctly plots the Julia set at an appropriate neighborhood of infinity, but:
1) Axes are not transformed
2) Saving as .eps produces an empty plot, sans the axes (plot is saved correctly, when not applying mu(z))
Is there any trick to force the axes to also show correctly with the transformed ranges?
Seems that this misalignment is bothering the .eps renderer, which probably plots the graph in twilight zone, given the false ranges of the untransformed axes.
Any ideas on how to force the saveas .eps to work in this case?
Many thanks,
Yiannis
