Question: Numeric solution by Runge-Kutta method
Hello
I am trying to slve the second order differential equation with initial conditions  t0=0.dy/dt=0,y0=10000
-(diff(y, t, t))-9.81+0.563e-3*(0.1832e-2*abs(diff(y, t))+0.51702e-1*abs(diff(y, t))^(3/2)+.4*(diff(y, t))^2) = 0
using 4th order runge kutta.do i need to declare a step parameter like (D(y))(t) = u or is a command that can be applied automatically?
 rk4.mw
