Question: Problem with applyrule
can you please help me with the usage of applyrule? I have the following problem that I cannot isolate. I have a rule that I want to apply, but instead of applying the rule to the expression, the rule seems to be applied to itself. In an isolated worksheet everything is fine:
rule:=abs(''a''::algebraic)^2=''a''^2;
abs('a'::algebraic)^2 = 'a'^2
myexp:=abs(548.477146186283171377723+radius_motor*q_mot_vec_2(t)-l_wire_0[2])^2
applyrule(rule,myexp);
rule
abs(a::algebraic)^2 = a^2
Download applyrule.mw
What happens when I try to use this rule in my script is this:
#read "some_long_script.mpl":
applyrule(rule,abs(x)^2)
abs(x)^2
rule
a::algebraic^2 = a^2
I want to clarify, that the script that is read before applying those rules does not apply a similar rule. Also the variables rule and x were free. Can you please help me to locate the problem?
Thanks!
Honigmelone
