Question: declare has a quirk
The following command works fine until you use it in the combination conjugate and diff.
example in Physics:
declare(phi(X));
diff(conjugate(phi(X)),x1);
phi(X) should now appear as phi with index x1 and a bar only, but
it comes as phi(X) x1 , the declare command is not effective. Non conjugate works fine.
Any idea - thanks in advance
