Question: How to specify solution range for solve
Hey,
I want to solve this equation and looking at the plot there are at least 3 solutions. I want the greatest/smallest negative solution. Unfortunately using solve with assumptions produces no results and solve without assumptions only finds two solutions.
Can you please help me?
#select greatest negative value from solution
expr:= ax*cos(lambda)+ay*sin(lambda)-(a+b*lambda)
ax*cos(lambda)+ay*sin(lambda)-b*lambda-a
ax:=1:ay:=2:a:=0.5:b:=0.25: #examplanatory values
plot(expr)
assume(-2*Pi<lambda,lambda<0): #does not work
sol_lambda:=[solve(expr=0,lambda, useassumptions)];# returns empty list even though without assumption one solution is found
Warning, solutions may have been lost
sol_lambda:=[solve(expr=0,lambda)]; #returns only two solutions even though looking at the plot 3 are there
Warning, solve may be ignoring assumptions on the input variables.
[2.190357220, -.2688724573]
sol_l_v:=evalb~(sol_lambda<~0); #dirty workaraound
[false, true]
sol_l_add:=[ListTools:-SearchAll(true,sol_l_v)] ; #this seems overly complicated
[2]
lambda:=sol_lambda[sol_l_add[-1]];  #to select the last entry
-.2688724573
expr; #test
0.
Download select_solution.mw
Thanks!
Honigmelone
