Question: Manipulating equations and reassigning in equations template
I dragged into model space prismatic FixedFrame and RigidBody components and prismatic joint along y axis. I also set mass m = 1 kg. The manual says set K_S = K_S and K_K_d in inspector parameter setting. It did not work out. So i set values 12 and 0.1 for K_S and K_d. I sreated subsystem sub of rigidBody and followed the following instructions,
Quote" PrismaticJoint.PlacethePrismaticjointandRigidBodyinasubsystemcalledsub.Thisallowsthe EquationTemplatetogenerateequationsspecificallyfortheselectedsubsystem.
3. ClickTemplates( )intheMainToolbarandselecttheEquationstemplate. 4. IntheAttachmentfield,provideaworksheetnameandclickCreateAttachment.Your MapleSimmodelopensinaMapleworksheet,withtheSubsystemSelectionwindow.
ClickLoadSelectedSubsystem.Thesubcomponentparameterandvariablesload automaticallyintheParameterandVariableManipulationareas"
After this i wanted to modify the equations. I could not. The same equation is reassigned.
Parameter and variable rows - are as shown in manual, but a blank row not available for user's use. But how do i get the variable x(t) there and rename it?
Thanks for an example of this chapter with an application of its use., if available with anyone?
Ramakrishnan V
