Question: How to run a maple script directly from Terminal on Mac
Hi Maple friends,
I am trying to run a script I have written in Maple 2016 directly from my Terminal on my MacAir. I have OSSierra 10.12.1 and Maple 2016.
My script needs to read a file in and then run, whilst writing to some files on the way. I need this, since I want my script to be run on a large computer on my institute, where I have no interface/Maple open and has to access data on the way.
So, I go to Terminal, and stand in the directory of where the file/scrips is (lets call it terminal_test.mpl OR terminal_test.txt) and then write:
./maple terminal_test.mpl
and get back
No such file or directory
I also get this if I use .txt file AND if I write "Maple 2016" instead of ./maple. I have tried to write
open "Maple 2016" terminal_test.mpl
and then Maple opens in the right file, but does not run it. This is just to show, that my terminal can find the program. But this is not what I want. As I said, I would like it to:
start running a script from Terminal - read a file to be used in the script - on the way, write to 6-8 different files, that I can then access whilst the script is running. So my questions are:
  1. How do I run the script/file in the first place, and am I in the right place?
  2. Where do I place the files to be read during the running of the script (Reading to script works fine already, so it should work also if I can just run the script/file)?
  3. Where do the files I create in my script end, so I can access them?
Thank you so much for any answer - I have not been able to find anything on the net so far that could help me, but I know you guys are really good on this.
Tomas.
