Question: How many solutions has "solve" found?
I have 6 equations, eq1,...,eq6, with 6 unknowns a,b,c,d,f,g. I can find all the solutions with "solve".
If "solve" has found only one solution, then the ith solution number is given by sol[i]. For example,
c:=sol[3]. This comes from
sol:=solve({eq1,eq2,eq3,eq4,eq5,eq6},{a,b,c,d,f,g});
However, if solve has found more than one solution,
then the jth element of the ith solution is sol[i][j]. It is thus imperative to know how many solutions
the command "solve" has found. Also, how do we restrict "solve" to look only for real soultions?
Thank you very much!
mapleatha
