Question: How to remove equation labels? in Maple
Pl. help me remove the equation labels or hide the equation labels in my doc enclosed. What should i do to prevent equation labels from forming in my document. Please refer last two rows in the table below from the document.
Thanks for helping.Ramakrishnan V
Conversion from ppm to % vol is 1ppm = 0.0001 %
Conversion from % vol to ppm is % = 10000*ppm
Avagadro's law between mass and volume is
"22.4 nm^(3)=1 kg mol; 22.4 lit = 1 g mol; at  101.325 kPa*(normal pressure) and (273+C ) K;"
ppm = 0.8205e-1*T*mg/(M*nm^3); mg/nm^3 = M*ppm/(0.8205e-1*T)
where T is abs temperature and M is molecular weight;
M/(0.08205T)]*ppm*((A/F)*EA+1) /ρex; Emission is mg/kg fuel
If SFC is x g/kWhr; then Mass flow of exhaust is  (x/1000)*[M/(0.08205T)]*ppm*((A/F)*EA+1) /ρex; Emission is mg/kWhr
If the distance covered per liter is DCL km/liter, then (SFC/1000)*(DCL)/`ρ__f`  is distance covered in km/kWhrNULL
[kg*km/(kWh*liter)*(liter/kg) = km/kWh]
1 g/cc = 1 kg/lit; 1kg/m3 = 1 g/lit; Fuel density`ρ__f`  is 0.77 kg/litNULL
Emission in mg/km = 0.77*Emission is mg/kg fuel/(km/liter fuel)
[(kg/liter*(mg/kg))*km/liter = mg/km]
SFC is in g/kWhr
Measured emission is  E in ppm  ``
Excess Air percentage is EA in per unit point
Molecular Weight of pollutant is M g/mol
Molecular weight of air = .21*32+.79*28 = 28.84 g/mol
SFC
       SFC := 200 g/kWh
`ρ__f`
rho__f
        `ρ__f` := .77   kg/liter
DCL
   DCL := 50    km/liter fuel
A/F
AFR := 14.5``
EA
EA := .1NULL
T__exh
T__exh
   T__exh := 450     K
`ρ__ex`
rho__ex
      `ρ__ex` := .457 kg/m3
c := (AFR*EA+1)/`ρ__ex` = 5.361050328
CO
CO2
HC
NO2
O2
N2
Air
M [g/mol]
M__co := 28
M__co2 := 44
M__hc := 17
M__no2 := 46
M__o2 := 32
M__n2 := 28
M__air := 28.84
Emission [% ] or[ppm]
E__co := 10
E__co2 := 10
E__hc := 110
                ppm
E__no2 := 10
                ppm
E__o2 := 10
E__n2 := 10
E__air := 10
Emission [mg/Nm3]
0.8205e-1*T__exh/M__co
1.318660714
0.8205e-1*T__exh/M__co2
.8391477273
0.8205e-1*T__exh/M__hc
2.171911765
0.8205e-1*T__exh/M__no2
.8026630435
0.8205e-1*T__exh/M__o2
1.153828125
0.8205e-1*T__exh/M__n2
1.318660714
0.8205e-1*T__exh/M__air
1.280253121
Emission
mg/kWh
k__1 := E__co*c/(1.318660714)
= 40.65526690NULL
k__2 := E__co*c/(.8391477273) = 63.88684799NULL
k__3 := E__co*c/(2.171911765)
 = 24.68355489NULL
k__4 := E__co*c/(.8026630435) = 66.79079562NULL
k__5 := E__co*c/(1.153828125)
 = 46.46316216NULL
k__6 := E__co*c/(1.318660714) = 40.65526690
k__7 := E__co*c/(1.280253121) = 41.87492489NULL
Emission
mg/kg fuel
k__1f := k__1*SFC
 = 8131.053380NULL
k__2f := k__2*SFC
 = 12777.36960  NULL
k__3f := k__3*SFC
4936.710978
k__4f := k__4*SFC =
13358.15912
k__5f := k__5*SFC
9292.632432
k__6f := k__6*SFC
 = 8131.053380 =
k__7f := k__7*SFC
 = 8374.984978
Emission
[mg/km]
Why in the above row, col2 and col3 have no equn nos?
What should i do to remove the equn numbers 11, 12 and 13?
Temperature of exhaust is in T K
Density of exhaust is say `ρ__ex` kg/m3
DCL is distance covered per kWh
SFC := 100*g/kWh; ppm := 4.3; EA := .2; M := 28; `ρ__ex` := .457; T = 400
100*g/kWh
(14)
Emission in g/kWhr is
Emission g/g of fuel = Emission in g/kWhr/SFC in g/kWhrper
Emission in mg/km = 0.77*Emission is mg/kg fuel*(km/liter fuel)
Download ppm_to_g_per_km_conversion.mw
