Question: Finding the value intersection between two lines in 3d using geom3d-package
Hi I am trying to get Maple to find for which value k two parametric lines intersect using geom3d package. Is that possible?
my code is as follows.
restart; with(geom3d);
#First I define the the point and vector to construct the line l.
point(P, 1, 0, -2);
v := [1, 1, 2];
line(l, {P, v});
Equation(l) = [1 + t, t, -2 + 2 t]
#Next I try to define the line m.
line(m, [k*s+4, 2*s, 3*s], s)
but how (if possible to I get the line to take in the second paramter k?
and if its possible? which syntax do I use in the intersection-command to get Maple to print out the value k? so it still uses the parameter s for the intersection?
best regards
Fred
