Question: Performances of PolyhedralSets:-PolyhedralSet.
I would like to have some references about the function PolyhedralSets:-PolyhedralSet.
I used it very recently before constructing the convex hull  (PolyhedralSets:-ConvexHull) of a set of 50 points.
After some minutes spent to wait for a solution, I was forced to stop the computation.
I randomly sampled 10 points, next 20, 30, ... from the original set of points and observed that the computational time was growing very fast with the number of points.
Could you please inform me about the algorithm Maple uses and about its complexity?
Last point: the original points are floating numbers and I used the transformation  T: x -->  rounf(10k*x) / 10k (PolyhedralSets:-PolyhedralSet operates only on rationals).
It seems that the computational time increases strongly as k increases too.
What are the limitations and best practices to use PolyhedralSets:-PolyhedralSet?
TI1
